Too cool?
Old May 24, 2005 | 09:15 PM
SkunkApe's Avatar
SkunkApe
Default Too cool?
Just installed a hi-flo aluminum water pump, 16" elec. fan and an aluminum radiator. While apart, I also installed a Milodon hi-flo 180 t-stat.
Idling (in hot FLA sun), car reaches 170 (I'm using a quality manual-sender & guage).
Does this mean my t-stat isn't opening? Is this considered a "problem"?
Old May 24, 2005 | 09:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if anything it means the thermostat isn't closing ...or the guage is wrong ....or the thermo stat is calibrated wrong...
Old May 24, 2005 | 09:56 PM
BigBlockk's Avatar
BigBlockk
A cool running engine will tend to collect moisture in the crankcase. This can combine with unburned gasoline to form acidic compounds. Thermostats were developed to raise engine temperature quickly to prevent this. If this car were mine I would put a 195 degree 'stat in it. The engine will rid itself of moisture better and run more efficiently.
BigBlockk
Later.....
Old May 24, 2005 | 10:07 PM
SkunkApe's Avatar
SkunkApe
Yes, I've heard of the condensation issue.
But...if the temp never reaches 195, will the t-stat ever open? I don't think my 180 t-stat is opening as the temp doesn't get above 170.
Old May 24, 2005 | 10:16 PM
aharte's Avatar
aharte
There is no way that your engine would remain at a stable temperature with the thermostat completely closed. Your thermostat certainly is opening (at least partially) at 170 (or whatever your gauge claims is 170).
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
it sounds like your t-stat is opening at 170. if the t-stat never opened the car would over heat sense the colant in the engine wouldnt be making it back to the radiator to cool off. and like the others have said i would go with a 195 t-stat so that the engine could run at a more efficient temp.
Old May 24, 2005 | 10:27 PM
SkunkApe's Avatar
SkunkApe
OK. I understand now. There could be a 10 degree "margin of error". If the car is staying at a "stable" temp, that indicates water is flowing thru the rad (via the open t-stat).
Thanks.
Old May 24, 2005 | 10:38 PM
LIQUIDDRAGON
Thanks.
if its staying right at 170 then your cooling system is working perfectly with the t-stat working at 170 and not the advertised 180 so if i was you i would go get a 195 tstat. if the t-stat was stuck open then i you would see a temp of closer to 150-160 but i could be wrong but i dont think you would see 170. as long as your cooling system is working perfect it will hold the temp that the t-stat is set to.
Old May 24, 2005 | 10:43 PM
LIQUIDDRAGON
just had another thought. t-stats work off of heat and dont just open fully and close fully as it hits a desired temp so i was thinking that because your system is so efficient that what might be happening is that once the temp gets to 170 the t-stat is just starting to open and letting just enough coolent to flow through and not reaching the full 180 so you arnt getting that big coolant rush and bigger temp drop to fully close the t-stat so you might have a slightly open slower coolant flow but as always i could be wrong.
Old May 24, 2005 | 11:10 PM
VETDRMS's Avatar
VETDRMS
LiquidDragon: You would be surprised at how fast the t-stat's open when they hit their temperature, and I have found by boiling them in water with a temperature gauge that the good ones are quite accurate and start opening within 1-2F of the advertised number.
Old May 25, 2005 | 08:40 AM
CGGorman's Avatar
CGGorman
Of course, you were using a calibrated thermometer, distilled water, and conducting the test at sea level...right?
Old May 25, 2005 | 11:37 AM
VETDRMS's Avatar
VETDRMS
CGGorman: I just got this reply in my email, but it is not here:
I will assume that was directed at me. And yes as a matter of fact it just so happens that I have a mineshaft that is 3500' deep where I have a laboratory to test thermastats...
give me a break. :rollseyes:
Old May 25, 2005 | 11:59 AM
rihwoods's Avatar
rihwoods
Feel your upper radiator hose and tell us what it feels like,before/after warm up......
edit:never mind...you got it now...
Old May 25, 2005 | 03:35 PM
69schemers's Avatar
69schemers
It does not matter. Get rid of the 180 deg. and buy a 195. you will be better off.
Old May 25, 2005 | 04:08 PM
CGGorman's Avatar
CGGorman
I occured to me after I typed that reply that we weren't determining boiling point. Temp is temp. My only point was that 1-2* is too close to call with home equipment.
Good call on the mine shaft. I keep my wine in mine.
Old May 25, 2005 | 04:25 PM
mooneyd's Avatar
mooneyd
Alot of people misunderstand the purpose of the tstat. It regulates the minimun temp. of the coolant not the max. temp. It stays closed till the coolant reaches the temp. it is set for then opens. After that the coolant can run at 250 degrees or what ever, but if it goes below the set temp. the tstat will close till it comes back up to temp.
Putting in a 160 degree tstat will not stop the coolant temp from going over 160 degrees.
Old May 25, 2005 | 09:45 PM
chris75stingray's Avatar
chris75stingray
wow, this is the first time i have ever heard about a car running too cool.
To Too cool?
Old May 25, 2005 | 09:48 PM
SkunkApe's Avatar
SkunkApe
I was quite surprised. For years I've been running at 200+/- (and always driving with one eye on the temp gauge). Now, with the new water pump, elec. fan and radiator, I'm worried about running too cool...
Old May 25, 2005 | 10:28 PM
petronix's Avatar
petronix
Mine runs steady at 160, according to the guage. I asked the person I bought it from and he said that he installed a 160 thermostat (not sure why). Car has 72 L48 with a 327/350 cam and stock cooling system (new radiator). I think I may install the 195, as suggested here.
Old May 26, 2005 | 08:43 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
WHat motor do you have ? You might be the only C3 owner that has a properly workng cooling system or your temp gauge is inacurate
