always a story / Ignition Switch
I blew the engine in this car and replaced it. When I was replacing it I bought a new starter. So this year I've completed all the jobs and go to start the car ... the starter is making some real nasty noises ... sometimes it would turn over fine, other time it would turn over very slowly and then other times it would make a horrible noise. ahhh starter miss aligned so I placed some shims and no change to the above. No the starter is shot ..take the Starter out do a quick look inside .. ah good, no parts fell out .. bench test , and the starter works fine. So this leads me to my problem, my ignition switch must be shot ? I put the starter back in the car and wired up an mechanics starter switch ... no starter problem, everything works great.
Is it a hard job to take the ignition switch off the steering column ?
Is the Ignition switch fixable or should I buy a new one ?
If it's fixable what needs to be done.
thanks
Macgiver
These instructions and pictures on dropping the column are generic regardless of type:
http://www.corvettefaq.com/c3/T&TColumnD&R226NO04.doc
http://www.corvettefaq.com/c3/StrgCo...llationPic.doc
If you have a T&T here are the particular pictures and switch adjustment procedures:
http://www.corvettefaq.com/c3/T&TDisasmInstrPage3.doc
If you have a standard column here are the particular pictures and switch adjustment procedures:
http://www.corvettefaq.com/c3/StdC3C...InstrPage2.doc
Good luck,
Jim
I just found an area call Tech Tips ... where abouts is FAQ located in the site ? thanks newbe sorry
Dave
