Easier Shifting
Old May 27, 2005 | 01:27 PM
VETTE077's Avatar
VETTE077
Default Easier Shifting
Is anyone using synthetic oil in trans to make shifting smoother
Old May 27, 2005 | 06:39 PM
Duke94's Avatar
Duke94
I used it in my 78'. To be honest, I didn't notice a difference. Maybe in cold weather it's better.
Old May 27, 2005 | 07:43 PM
stingr69's Avatar
stingr69
Did not work for my Muncie. I would stick with the 90Wt. Dino oil.
-Mark.
Old May 28, 2005 | 09:48 PM
VETTE077's Avatar
VETTE077
I read somewhere a guy used Mobil1 50wt motor oil and said his c3 shifted smooth. I don't know if it would work.
Old May 29, 2005 | 12:15 AM
lucky76's Avatar
lucky76
Default Old transmission grease
I got my 76 with a T10 4 speed last summer and it wouldn't shift to 2nd very well most of the time. I adjusted the linkage but it didn't do any good.
I though I might need a rebuild but I thought I would change the transmission grease first. When I drained it, it looked like "mud" coming out and stunk like ????. I filled it up with 80/90 weight lub and drove it a few days. It shifted better so I drained it again and refilled it again. It now shifts as good as new. I guess the grease was 28 years old. I've changed the differential lub since then and it smelled really bad also.
Changing the transmission lub might be just what you need.
Lucky
Old May 29, 2005 | 03:58 AM
terry82's Avatar
terry82
i use it in my tractor .it did help .my 82 has a automatic or i would try it there too
Old May 29, 2005 | 01:17 PM
phclub's Avatar
phclub
New England Events Coordinator
Default How to
Lucky
Can you explain how you change the fluid, do you use a pump to drain the fluid and what is the proper refill quantity. My understanding is the trans is filled to the level of the drain plug.
To Easier Shifting
