Engine Pull
Old May 28, 2005 | 12:32 AM
swallace's Avatar
swallace
Default Engine Pull
Planning to drop the muncie tomorrow morning and then pull the engine. Anybody got any step by steps or 'whatever you do don't do this....' pointers
Old May 28, 2005 | 01:01 AM
tersian's Avatar
tersian
Sure, try and follow this. It's for an 81, but you'll get the idea:
http://forums.corvetteforum.com/show....php?t=1089923
Old May 28, 2005 | 07:52 AM
stingr69's Avatar
stingr69
Don't run out of beer.
Don't forget to drain all the coolant.
Don't forget to install new ignition wires BEFORE you reassemble the engine and put it back in the car. Lable the ends of the all the wires. This job is easy when assembling the engine but a TOTAL PITA after it is installed.
-Mark.
Old May 28, 2005 | 08:22 AM
Ganey's Avatar
Ganey
If your hoist isn't long enough to go in from the front, the engine can be pulled from the side.
Old May 31, 2005 | 01:13 AM
swallace's Avatar
swallace
Well thanks to everyone for the help. My forearms arms are bruised from wrist to elbow but it's out.
This thread was excellent Tersian
http://forums.corvetteforum.com/sho...d.php?t=1089923
And thanks Ganey for the tip about hoisting it from the side....that made the difference. Now if I can just find where it all goes when it's time to put it all back.
Old May 31, 2005 | 03:17 PM
tersian's Avatar
tersian
Glad to see it helped, if you wait awhile, it will eventually document putting an engine back in
Old May 31, 2005 | 11:18 PM
swallace's Avatar
swallace
How long I wait will depend on the oil analysis and what the cylinder walls look like when I pull the heads off. I'm almost positive the value guides are shot and that's where my oil burn has been coming from.
Old Jun 1, 2005 | 06:58 AM
cosmicvette's Avatar
cosmicvette
Good job dude
Good luck with your engine!
To Engine Pull
