OK, Am I Totally Screwed
Old May 28, 2005 | 02:56 PM
Richard Cooper's Avatar
Richard Cooper
Default OK, Am I Totally Screwed
I've done another stupid thing, I tried to wet sand the scratched out of my T-top. I used 1000 then 2000 grit paper. first I soaked the sand paper in water for 15 minutes. Then I sandes the top with 1000 and then 2000 paper. I kept the top wet while doing it with spraying soapy water on top. the top now has a REAL dull finish and it will NOT shine with the wax I put on. Am I screwed or is there some magic wax I can use? From now on I stick to mechanical ONLY. Thanks in advance.
Old May 28, 2005 | 02:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yu need to polish it out with a buffer and some fine polish you should be ok....Meguiars makes good products
Old May 28, 2005 | 02:59 PM
norvalwilhelm's Avatar
norvalwilhelm
Wet sanding leaves a dull finish and you need to buff it out.
Old May 28, 2005 | 03:01 PM
GDaina's Avatar
GDaina
there is also 2000 and 4000 grit paper....use those, after the 4000 grit paper, the finish will be a dull shine. The T-Tops, are they made of glass or some other material? You may need to buff them with a very very fine compound, 3M Perfect It III System has the compound. Don't use a buffer, but buff by hand.
Old May 28, 2005 | 03:43 PM
Witz's Avatar
Witz
Meguire's # 2 or # 3. Use a terry cloth towel or wash cloth. Squirt a little on and rub in with medium pressure until the liquid is gone. After that you will need some wax. Good luck!
Old May 28, 2005 | 03:46 PM
Richard Cooper
Is the polish you are talking about also called rubbing compound? And THANKS for the reply, you made my day.
Old May 28, 2005 | 03:59 PM
Dr.G's Avatar
Dr.G
use a medium grade of rubbing compound, 3M makes a good product, you can put this on by hand in a circular motion. It wont hurt the rest of the finish if you get it on it. Then use a good cleaner wax then a sealer wax. I would also suggest Maguires wax. good luck. This is a simple procedure
Old May 28, 2005 | 04:00 PM
bobs77vet's Avatar
bobs77vet
it goes in this order 1000 grit paper, 2000 grit paper, rubbing compound , polishing compound, glaze,wax.....different companies call it different things go to meguiars website for more info they make a great product
Old May 28, 2005 | 04:03 PM
GDaina's Avatar
GDaina
Oops...me bad...for some reason I thought the tops were clear...forget what I said about a buffer, ok to use it....
Yes, rubbing compound, but use the fine grit
To OK, Am I Totally Screwed
