"Dieseling" on shut down
Old May 28, 2005 | 06:08 PM
VolVette's Avatar
VolVette
Default "Dieseling" on shut down
When I shut down my '75, it "diesels" or fires a few times after I have turned the key off. When I shut it off, the RPM's are high (between 1500-2000RPM). Recently my temperature guage quit working and I'm wondering it there might be something wrong with my water temperature that could relate to my high idle RPM's and "dieseling."
Old May 28, 2005 | 06:15 PM
terry82's Avatar
terry82
why does your car idle so high? fix that problem and your other problem should go away .check for vaccume leaks.
Old May 28, 2005 | 06:16 PM
Empatho's Avatar
Empatho
My 78 had the same problem for a week and then it stopped doing it
Old May 28, 2005 | 06:47 PM
BigBlockk's Avatar
BigBlockk
Why are you shutting it down with your foot still on the accelerator? If you're not doing that there is something wrong with the ignition, carburetor or both. Is the timing set right? Retarded timing will force you to raise the idle speed on the carburetor to keep the engine running. Is the choke adjusted correctly? Are there any vacuum leaks?
BigBlockk
Later.....
Old May 28, 2005 | 07:01 PM
ETM's Avatar
ETM
drop the idle down.
Old May 28, 2005 | 07:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
turn it of in gear until yu fix it...
Old May 28, 2005 | 10:18 PM
VolVette's Avatar
VolVette
I should have mentioned that it's an automatic.
Old May 28, 2005 | 10:22 PM
bobs77vet's Avatar
bobs77vet
even better turn it off in gear....just turn it off in drive or reverse , no problem
Old May 28, 2005 | 10:38 PM
VolVette's Avatar
VolVette
Is this just so the RPM's are lower? Or what's the idea behind doing that?
Old May 28, 2005 | 10:48 PM
bobs77vet's Avatar
bobs77vet
the cars stalls and can't run on, it is not the solution but stops the embarassment
Old May 29, 2005 | 05:28 PM
ewalker302's Avatar
ewalker302
I have the same problem with my 79' bronco due to higher compression, and reg gas. If I run midgrade tho, it never diesels.
Old May 29, 2005 | 05:35 PM
Matt Gruber's Avatar
Matt Gruber
the engine stops. i learned this in 1970 with a 70 duster(i left it kickin', when i came back 10 min later, it was still kickin'[company car )
Old May 29, 2005 | 05:47 PM
StickShiftCorvette's Avatar
StickShiftCorvette
You should get your idle down below 1000 RPM.
You could also add an idle solenoid so the air is blocked when you shut down.
Old May 29, 2005 | 09:38 PM
bobs77vet's Avatar
bobs77vet
i was just thinking the same thing....any body who drove cars in the early -mid 70s learned that trick.
Old May 30, 2005 | 09:18 PM
jpw73vert's Avatar
jpw73vert
Since I started using a fuel additive called Max Lead 2000 on the recommendation of another CF member, it cut down the dieseling. Also gets rid of the major fumes and gives you some more power as well. You can buy it direct from the mfr., which you can find on the web if you do search on the name of the product.
Old May 30, 2005 | 11:56 PM
greyghost79's Avatar
greyghost79
if engine's been running rich for a long time you may have excessive carbonization in the cylinders which raises compression ratio and can cause dieseling problems.
Old May 31, 2005 | 12:24 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I had a similar problem on 87 octane.. I stepped up and the issue is gone
To "Dieseling" on shut down
