Ok, I got everything installed, everything wired up (I think). I put a new coil, dist cap, and rotor in. I got fuel flowing, spark from the coil but it is not turning over. Any thoughts?
Im working with him buddy,hes going to check a few things out.Hes got spark out of coil wire and into cap but nothing coming out of cap,he replaced cap and rotor too.
You gotta get spark to the plugs of course. Also can check to see if the injectors are pulsing (with a Noid light). Also make sure your distributor is not pointing 180 degrees out. That happens to the best of us....
Your right mark hes checking that now,and the next thing is the injectors pulsing,his spark might just be weak and not seeing it as well but injectors not pulsing.OR if its got enough fuel pressure too.
Well from what I can tell, its got good fuel pressure, the injectors have power, I got spark going from the coil to the distributor, but it doesnt look like I have any spark coming out of the distributor cap.
What kind of fuel pressure do you have at the rail with key on? If you block the return line BRIEFLY, what is it?
How are you checking to see if the injectors are pulsing? Noid light? Analog volt/ohmmeter? Special tool? Check at least 1 lead on each side of the engine. TPI is batch fire.
If you do have spark to the cap, but not out there is not too much to go wrong. Check several different wires and different plugs. Be sure it isn't 1 bad wire or 1 bad plug. Replace cap, rotor, wire, or plug as required.
Be sure that the rotor is pointing to #1 at TDC and not 180 out. I've had several newly installed engines not start due to this. I used to be very paranoid about distributor removal (dropped an oil pump shaft in an FE Ford-must use retainer ring on a Ford). Not an issue on a Chevy. Do not be afraid to remove a distributor.
I think this is a fairly simple problem to solve. It sounds like the spark module in the distributor has gone bad. This is the piece that times the dwell, electronic version of the points, its probably just burnt out. There should be three wires to hook up. One to + side of coil one to - side of coil and one to 12V.
Another thing you need to be aware of, is some corvettes that were orignially points used a resistor wire to the coil. These need to be cut back and replaced with a non resistor wire to get full 12volts to the ignition. This may keep the later model distributor you have from distributing spark because there is not enought voltage to work the module.
try replacing the rotor with another one. My cousin had this same problem last summer on his 350 vortech. Had a complete tuneup, cap, rotor, plugs, wires, etc. Drove 1k miles down to the family reunion after the tuneup, then all of a sudden the truck instantly stalled. No warning or anything. Traced the spark to the coil, but not coming out of distributor. Bought another rotor and all was good.
I see what he is saying too. How did you check for spark at the coil?
He has spark now module was bad,but we think the injectors arent firing,he can spray carb. cleaner down throttle body and it fires up.HEs gone to check the pick up coil next.I wonder if his setup has vats or not,if it does theres the problem.But if i rmeber right he said it was a 87 firebird setup which doesnt use vats yet.
Need check he has 5 volts on high side of all the sending unit.s make that TPS and MAP.....if not, you know there is 3 imputs to a stock type computer for 12 volts, one for each injector bank, and another for the internal 5 volt regulator, without that 3rd input having 12 volts, that's what you have....
I just listen to injector firing with a stethescope, hear all even sounding clicks.....tells me they are normal...don't forget they are supposed to 'float' on the rubber gaskets/o rings and turn relatively freely so there is not real mechanical connection between the injectors and engine/intake/fuel rail......
May want to be damn sure the middle finger 'clip' from the coil frame to ground picked up by wiring was not forgotten in the new coil install, that will also mess things up really badly...in fact the engine may run like that because the spart ALSO jumps from that coil frame, which is seeking a ground return, to the coil or Bat side.....don't ask just exactly HOW I know this...OK??
Sounds like a VATS issue. If you have the PROM number I can look it up and see what it came out of. Need the number off the PROM, not just the ECM. If it is from an 88, you will have to have it reburned or get an earlier PROM. Sounds like you are getting very close.
Mark he pulled the dist. and found the magnetic pickup plate cracked so hes trying to find one now,he checked to see if he had vats and the wire is not there in the ecm,it was a 88 trans am setup so hes not sure if it has or not,id say not.Well its no vats,i m gone to help him tonight and call him and check each wire and make sure everythings doing what its supposed to do.
Were(lol) hes pretty close now,traced all the wires out and found a few with no power,hes working on timing issue now,its trying to start now,Hell get it running by tomorrow no doubt.The prom was no vats .
