Anyone here using a turtle?
Old Jun 2, 2005 | 03:23 PM
gerry72's Avatar
gerry72
Default Anyone here using a turtle?
Why would you use a turtle, you ask?
Old Jun 2, 2005 | 04:07 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
First time I have ever heard of such turtles. I think I would be scared off by the warning at the bottom of the page unless you had a brand new intake. It would probably be bad things if one of them ever got loose.
Old Jun 2, 2005 | 04:46 PM
Gordonm's Avatar
Gordonm
I have seen these but never seen what kind of HP they make. Lets see some dyno results on this.
Old Jun 2, 2005 | 04:57 PM
Tex71BB's Avatar
Tex71BB
They look too big to go down a port.
Old Jun 2, 2005 | 05:00 PM
gkull's Avatar
gkull
Very popular item about 12-15 years ago when people were bench flowing victor jr single plane intake manifolds.
That's One of the reasons why I have stayed away from Edelbrock intakes. Very poor fuel distribution and flow rate between individual cylinder runners. People spent lots of man hours epoxying in "turtles in the bottom of the plenum to adjust the flow.
Old Jun 2, 2005 | 05:28 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i don't have one but i guess i should
Old Jun 2, 2005 | 05:48 PM
rihwoods's Avatar
rihwoods
Old Jun 2, 2005 | 06:20 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Hmmm...isn't that like the gizmo that goes inside the air cleaner...Tornado something-or-other? Causes the air to whirl around like a tornado. Let me check my Popeil catalog. Think it's right next to the Pocket Fisherman.
Dep
Old Jun 2, 2005 | 06:32 PM
CGGorman's Avatar
CGGorman
Dep, behave. This is BRODIX we're talking about...
Old Jun 2, 2005 | 06:35 PM
DonBecker's Avatar
DonBecker
No numbers = BS in my book.
Old Jun 2, 2005 | 07:19 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Dep, maybe it'll make the 302 behave like a big block.
Old Jun 2, 2005 | 08:43 PM
toddalin's Avatar
toddalin
I would NEVER put my Turtles in a Corvette engine for two reasons:
They're shaped like bathtub Porsches and run about the same speed as a Porsche! (Because of these facts, the larger one is actually named Porsche!)
Old Jun 2, 2005 | 11:15 PM
DJ Dep's Avatar
DJ Dep
Popeil/Brodix Tornado Turtle...I found it on page 26 of the Shop At Home catalog right next to the Ab-Blaster
Dep
Old Jun 3, 2005 | 02:58 AM
ltlevil's Avatar
ltlevil
INSTALLATION INSTRUCTIONS - VERY IMPORTANT
Manifold and insert must be absolutely free of contaminants such as fuel, oil, etc. A good degreaser/cleaner should be used before installation.
WARNING:
If mating parts are not absolutely clean and free of contaminants, insert could become dislodged.
I guess gkull verified this with the epoxy thing but damn the way they made it sound I was wondering if it was going to disolve if fuel touched it. Or maybe it would erupt, it does kind of look like a volcano. I might get one of these and mount the tornado directly on top of it. I will also direct two of my fogger nozzles so they will help the tornado spin a little faster. Hell man I would have a nitrous driven, tornado spinnin turtle port injected bad *****' RMAOL I might even get a patent on it; think I'll call it the "Petite Obscure Supercharger" or POS for short. On top of that I will get either the OxyClean guy or the Gazelle guy to market it for me!!!!!! What do ya think?
Old Jun 3, 2005 | 12:21 PM
gkull's Avatar
gkull
The actual aluminum turtles were odd shaped and a 4 leaf clover might be a good description.
I had a single plane modified with aluminum slats and contoured in with JB Weld. It looked like a work of art and actually made my motor have nearly equal primary header tube temps. Before the work the inner four cylinders ran richer than the outer four corners.
The idea was sound, the use of JB Weld was very flawed. Within a single plane manifold you have terrific air fluctuations and then add a couple of backfires and one of the pieces broke loose. Lucky for me that it was two big to actually go down into a cylinder. But at the JB Weld fed through. When I took off the carb for some reason much later I found this large piece of cast aluminum polished from bouncing around almost as if it were a rounded river rock.
Epoxy seemed to hold better, but I'm very leary of any parts under the carb
Old Jun 3, 2005 | 03:43 PM
isosceles's Avatar
isosceles
I thought the pocket fisherman was a Ronco product
Old Jun 3, 2005 | 05:18 PM
DJ Dep's Avatar
DJ Dep
It is. Ron Popeil. He owns Popeil and formed Ronco after his wife divorced him and tried to get the company assets of Popeil.
Pretty cool guy actually.
I think the Tornado gizmo is from some Oriental dood.
Wu Pflung Dung is his name, I think
Dep
To Anyone here using a turtle?
Old Jun 3, 2005 | 07:06 PM
CGGorman's Avatar
CGGorman
Well, you guys can scoff if you want, but serious engine builders have been using various tricks to balance port distribution for decades.
My dad's engine dyno has several sets of dedicated headers with pyrometers in each primary to monitor individual cylinder combustion temps. He used various methods to balance distribution; selectively porting the plenum-runner transitions, carb jetting, spacers, home-made "turtles", etc.
If a little guy in Fly-Speck Ohio knew about this in the 70's, it must have some merit.
By the way...he built/dyno tuned this engine:
Old Jun 3, 2005 | 07:26 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Hell, I thought those things went a way.
I remember seeing those around the dirt circle tracks in the mid-west. The late model and modified cars running large open intake manifolds were playing around with them. I haven't seen them since and thought they were gone for good.
Old Jun 3, 2005 | 07:40 PM
DJ Dep's Avatar
DJ Dep
WOW!!! Great article!!! Love that twisted carb mount Tarantula/Torker manifold!!! I got a whole basement full of Tarantula TM2R manifolds.
Back in the 70s when the open plenum single plane manis came out there were a lot of guys making custom mods to divert the flow of air/gas more effectively.
Dep
