ticking noise after water pump install
Old Jun 2, 2005 | 06:42 PM
tonyk72's Avatar
tonyk72
Default ticking noise after water pump install
What could it be? The noise coincides with RPM's...Could it be a loose alt. or AC belt? So far the engine is running cold, haven't got her up to operating temps yet.
nevermind...I'm all set.
Old Jun 13, 2005 | 09:44 PM
72hawk454's Avatar
72hawk454
Check your fan's shroud clearance. If you didn't get the shroud back in the exact spot this could be the problem.. I'm sure you did this, but take a hard serious look all around. This did happen to me. I've a tight shroud and after some work under the hood I managed to move it 1/4 inch closer inadvertantly. Under rev it made contact...ouch.
I assume you didn't have any fan wobble?
hawk
Old Jun 14, 2005 | 11:55 AM
flood's Avatar
flood
The shrouds can be a PITA
Old Jun 14, 2005 | 07:33 PM
GaryS's Avatar
GaryS
I had this exact thing happen on a 73 BB. We installed the fan to hub backwards. Once we turned it around the ticking stopped.
Gary
Old Jun 15, 2005 | 11:27 AM
vettfixr's Avatar
vettfixr
Check one more thing. On the waterpump hub there are studs that are installed that hold the fan assembly. Sometimes when installing the studs you can install them too deep and they will stick out the back of the hub. Check to make sure they are installed properly and not hitting anything.
Old Jun 15, 2005 | 12:16 PM
comp's Avatar
comp
so what was it
Old Jun 15, 2005 | 02:15 PM
tonyk72's Avatar
tonyk72
It was the AC compressor...
Thanks for all the suggestions guys.
To ticking noise after water pump install
