can I grease u-joint caps to ease installation?
Old Jun 4, 2005 | 05:57 PM
Frankenvette's Avatar
Frankenvette
Default can I grease u-joint caps to ease installation?
I'll be installing u-joints for the first time ever. I've cleaned all the u-joint bores with fine grit sandpaper. Can I use some synthetic hightemp grease on the u-joint caps (or in the bores themselves) to help them slide into the bores?
Old Jun 4, 2005 | 06:04 PM
norvalwilhelm's Avatar
norvalwilhelm
Definitely yes. I lube with normal engine oil the u joint bores before installing the universal.
Old Jun 4, 2005 | 07:48 PM
Frankenvette
Thanks for confirming my thoughts.
To can I grease u-joint caps to ease installation?
