edelbrock intake difference
Old Jun 5, 2005 | 02:33 PM
gator79's Avatar
gator79
Default edelbrock intake difference
what is the difference between an edelbrock performer and a performer EPS, are they the same height?
Old Jun 5, 2005 | 02:59 PM
American Boy's Avatar
American Boy
As I recall, they have the same height but the EPS have special port to promote the midrange power for towing application.
Stephan
Old Jun 5, 2005 | 04:23 PM
1970-Bronze's Avatar
1970-Bronze
The ESP is about 0.25" taller at the center point.
I have the ESP on my mine but I haven't had much seat time since installing.
Old Jun 5, 2005 | 04:54 PM
smthnpls's Avatar
smthnpls
Does anyone know if these intakes are higher then stock intakes? I have a performer and I would love to put it on my 79 L48 (rebuilt - .30 over, cam, stock heads for now, stock exhaust). I still have the double snorkle air cleaner. Also still using a reman Q-jet carb.
Old Jun 5, 2005 | 06:21 PM
American Boy
I run a Performer intake with a Quadrajet and stock dual snorkel a.c. and it fitted with a little help under the stock hood. I just had to lower the air cleaner by 1/16" approx.
Stephan
Old Jun 5, 2005 | 08:30 PM
smthnpls's Avatar
smthnpls
thanks Stephan.....
How did you lower it 1/16"? Did you notice a difference in performance?
Old Jun 5, 2005 | 09:29 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Also, I believe the regular performer for a small block chevy is a spread bore intake where as the EPS is a square bore intake.
Old Jun 6, 2005 | 07:11 AM
VETTE077's Avatar
VETTE077
Correct' The EPS is for a square bore. I am using a EPS with a Edelbrock 1406 600CFM and drop base air cleaner on a 77 with no clearance problems and made a big difference.Engine just seems to run better overall with this manifold.
Old Jun 6, 2005 | 05:00 PM
American Boy
thanks Stephan.....
Bubba took my hammer and did it. I gently bend the part that goes on the carburator. It could be cut too with a rotary tool.
The performance increase was from a stock L-48 to a roller cammed vortec engine so I can't tell about the intake alone.
Stephan
Old Jun 6, 2005 | 06:05 PM
smthnpls's Avatar
smthnpls
Thank you again
Paul
Old Jun 7, 2005 | 11:20 AM
Pauld's Avatar
Pauld
To edelbrock intake difference
