Intake Manifold Gasket
Old Jun 5, 2005 | 03:53 PM
mvftw's Avatar
mvftw
Default Intake Manifold Gasket
I have to replace my intake gasket, I'm sucking up way to much oil. I just did valve seals (which were gone), but I'm still going through oil. I did them last year with Fel-Pro 1204's. I've read here that I should use 1205 (printoseal). What about Mr. Gasket's Ultra Seal's???
Old Jun 5, 2005 | 08:38 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Are you SURE it's the intake manifold? I changed mine last month, it was leaking antifreeze fron driver side rear, I used the Fel-Pro.
Old Jun 5, 2005 | 11:43 PM
bigvette1's Avatar
bigvette1
How can you tell if the guides or the intake is the source of sucking oil?
Old Jun 6, 2005 | 12:22 AM
Contrail's Avatar
Contrail
If the intake gaskets have oil on them, there is your indicator of the intake sucking oil. I used the Ultra Seal gaskets and went around every port and bolt hole with black rtv. NO leaks. I also let it cure for 48 hrs after assembly.
Old Jun 6, 2005 | 09:02 AM
mvftw's Avatar
mvftw
I don't know, but I just replaced the seals with umbrella & o-rings and it didn't even slow down. No water, leaking just oil consumption. I don't want to do this again. I just want the best gasket...
Old Jun 6, 2005 | 04:05 PM
mvftw's Avatar
mvftw
Contrail, did the black RTV hold it in place or did you have to tack it also?
Old Jun 6, 2005 | 04:15 PM
gkull's Avatar
gkull
i've always used FelPro, but just a couple of weeks ago i needed to replace mine and summit didn't have my size FelPro in stock. so i got the Mr. Gasket. It worked OK for me
Old Jun 14, 2005 | 02:06 PM
Contrail's Avatar
Contrail
The RTV held it in place. I let the RTV sit for 10-15 minutes before I placed the gaskets on it. Then I RTV'd all the bolt holes in the top of the gasket and waited another 10-15 min. before I set the intake in place. So far, no leaks.
To Intake Manifold Gasket
