cam swap
Old Jun 6, 2005 | 05:15 PM
painterman52's Avatar
painterman52
Default cam swap
I`ve got an eb performer cam with 204 & 210. I`ve got the dart summit heads & 2.5 duals. I need to swap cams. I`m not sure which cam. Can one be taken out and the new one put in without changing the lifters or adjusting the valves or is this a pretty labor intensive project. I had the performer cam put in last year, I new it was to mild right away. Then with the new heads it seems theres a lot of performance to be gained with a hotter cam.
Old Jun 6, 2005 | 05:19 PM
Nate '69's Avatar
Nate '69
Huge job especially if you haven't done it before. You could move up to a <220@.050 cam but you may be happy with what's in it now too. At least tune it up first.
http://www.bokonon.net/corvette/cam1.html
