buzzing relays....what makes a relay buzz?
It has worked in the past.
Have you tried calling MSD??
i wonder if i could have a faulty relay?
Based on this assumption, I would try wiring it per the drawing below. Diodes D1 & D2 can substituted with the 1 amp diodes you already have. They aren't neccessary for the circuit to work - they just clamp the voltage spike when the voltage is removed from the relay coil.
Relays have a rated minimum "pull -in" voltage, however they also have a rated voltage to stay "on". I think your MSD switch may have some resistance in it's switching circuit with a path to ground which lets the relay coil turn on / but not enough to "hold" / which makes it buzz (fast switching on/off)
My schematic includes a 100K ohm (1/4 watt) resistor (R1) to "pull up" the switching circuit when it's in the "off" state. This effectively puts +12V on both relay coil terminals keeping it off because the voltage drop across the relay coil is zero volts. When the MSD switches, it grounds the relay coil & resistor which turns the relay on. The current through the resistor at this point will be minimal ~ 120uA, so it's not a concern.
I can't post the pic here because my Photobucket bandwidth limit has been exceeded for this month due to all the HOT ROD Power Tour pics I posted recently
but you should be able to use the link below to go there directly - click on the thumbnail and get a large view.Again, this is based on a guess as to the MSD box, so if it still doesn't work right, let me know & I'll dig
for some more info on it.
link to schematic
Hope this helps, let me know how it works out.
[IMG]
[/IMG]
its a sealed cube
Greg.
Greg.
Edit: I just found this quoted on another website:
"We discovered that the MSD rpm switch was not 'snap action'. It shuts off in a 'pulse width modulated' fashion over a range of a couple of hundred rpm. This would cause the solenoids to 'chatter' on and off in that rpm range."
They were trying to control fuel flow with a solenoid & had what sound like the same result you had with the relay. I'll keep trying to get the schematic & help with a solution, but it's getting late here now, so I'm done for today!
Greg.
ok i spoke with a different MSD tech and he said i should have no "ground circuit leakage" and he thinks its a bad switch, i will pick a new switch up on the way home from work, and a new relay from an auto parts store..where do i find those relays that require full voltage to pull them in? do they have a specific name? i can't get that expensive MSD relay until tomorrow and i'm wondering if that is set up to work with MSD differently then regular relays?
and i will test my new MSD switch before i put it in using this methodology......hook it up to ground, +12v, connect to Tach signal....(yellow wire is switched open normally, and closed at selected RPM this is the wire that goes to the new relay) so when i test it, it should have an "infinite amount of resistance" between the yellow wire and MSD ground at under the prescribed 1300 RPM indicating an open ground circuit....at the prescribed RPM the resistance should go down to zero indicating a completed ground circuit. what do you think?
heres my PLAN B if my new fancy MSD RPM controlled switch and relay doesn't work i may just use a SPST switch and hook up the SPST switch to the relay ground circuit and turn it on and off by hand as i enter/leave the highway it would also save me $$$ from my fancy RPM hook up....
thanks for al the help and if theres any more ideas i would like to hear them, i kind of enjoy the chase.....i guess i really am touched....thks bob
do you suppose a SPDT relay is less inclined to chatter then a SPST relay?
Shouldnt make any difference. They are the same coil but have 2 sets of contacts instead of one. Your problem isnt the relay, its the switch.
Greg.
thks Bob
