1978 350 distributor problems
Old Jun 7, 2005 | 07:30 AM
JustinD's Avatar
JustinD
Default 1978 350 distributor problems
Inside the distributor of my 350, there is a "half moon" shaped electronic peice. It is black and has 4 hook ups on it. This keeps going bad I even tried getting a whole new distributor, but it went bad again. Does anyone know what the problem could be?
Old Jun 7, 2005 | 08:06 AM
TJ76's Avatar
TJ76
Are you using the supplied grease to shield it from the heat?
TJ
Old Jun 7, 2005 | 08:33 AM
Paul L's Avatar
Paul L
Di-electric grease must be used on the underneath surface of the module. This aids in tranferring heat to the main distributor body.
Old Jun 7, 2005 | 09:01 AM
swtato's Avatar
swtato
St. Jude Donor '05
HEI module, as said before make sure you appy the grease.
To 1978 350 distributor problems
