Emergency Brake Cable Mount
Old Jun 7, 2005 | 09:42 AM
Jersey8t2's Avatar
Jersey8t2
Default Emergency Brake Cable Mount
Has anyone had to relocate the mount where the emergency brake cabel is welded by the rear tire. I bought a set of Weld rims and it wont go over the mount where the cable is. I read a article some time ago about moving this mount in order to run a drag tire. Could use some help.
Old Jun 7, 2005 | 09:47 AM
NHvette's Avatar
NHvette
Move the bracket from the outside to the top of the trailing arm.
Some welding required.
Old Jun 7, 2005 | 10:55 AM
68/70Vette's Avatar
68/70Vette
Trying to remove the existing bracket from the trailing arm will probably damage it.
I bought a new set of brackets. They only cost a few dollars. I believe I bought them from Volunteer Vette (forum sponsor).
68sbShark's Avatar
68sbShark
I actually just did this last week. Here is a post I put up a while back asking the same info. Got some good responses and a link to an article ( I think it may be the one you are referring to) on corvettefaq.
http://forums.corvetteforum.com/show...ark&forum_id=3
Good luck
~Rich
To Emergency Brake Cable Mount
