cam change
Old Jun 7, 2005 | 02:01 PM
gator79's Avatar
gator79
Default cam change
does the a/c condenser have to be removed to change the cam in a 350. it looks like the radiator and hood have to go for sure
Old Jun 7, 2005 | 02:07 PM
gkull's Avatar
gkull
The hood never has to go even removing the motor.
I just lay the belt driven items over on th sides.
Old Jun 7, 2005 | 02:10 PM
Gordonm's Avatar
Gordonm
I have pulled my motor without removing the hood. The rad. and condenser will have to come out but leave the hood on.
Old Jun 7, 2005 | 06:15 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I just did this on my 77... the rad comes out easy, the shroud is easy... youhave to pull the condenser or if you have 3 elbows, loosen the fittings on it and totally undo it and then slide it down.. I just took mine out anyway.. it didnt work and was empty anyhow...
To cam change
