Here is a motor for Dep
http://chevyhiperformance.com/techar..._0506_thunder/
You are right that this would be one expensive engine - not only the cost of the engine but many of us would be replacing our trannies, rear end etc.
"Grady began with a cast-iron, two-bolt main bearing block..."????
I didn't see any restrictions in the rules saying they couldn't use 4-bolt mains.
"...this 355 made 632 hp at 7,500 rpm and 502 lb-ft at 5,900 rpm."
Awww heck...most guys on the forum wouldn't like that motor...not enough tork!!!!
"Accurate vacuum plasma ion treatment"
I think I had that done to my back when I went to the Cairo-practer.
An interesting exercise in building a motor with unlimited funds.
Dep
A seasoned two bolt main block with standard bore and 010/020 casting is the ideal starting point for a high performance small block.
ask me how rock solid my bottom end is... (don't take that the wrong way)
the blonde weasel
Then onto top of that they use modern Vortec heads. I guess they never heard of fulie heads and something called a 302. Sure looks like they wasted a bunch of time and money, when they could have built an old school 302 based on 30+ year old technology. It's a shame that they are limited to 362ci, it would have been more entertaining to see them use a higher torque 3.75" crank.
Then onto top of that they use modern Vortec heads. I guess they never heard of fulie heads and something called a 302. Sure looks like they wasted a bunch of time and money, when they could have built an old school 302 based on 30+ year old technology. It's a shame that they are limited to 362ci, it would have been more entertaining to see them use a higher torque 3.75" crank.It WOULD have been interesting to see a full blast 302 built with unlimited funds like they did with this motor. No exotic blower or turbo, just conventional induction.
Here's what was done by the factory back in 1969:
http://www.camaro-untoldsecrets.com/...s/crossram.htm
458 HP from the 302 @ 7200 RPM
Dep
I just found it. It was August of 1975. That was the first year I started reading HR. They were using the Turbo heads exstensivly modified and a tunnel ram intake. It was running around 12.5 to 1 compression. The ultra exotic heads as they called them cost 2000 dollars back then. Big bucks for 75.
Dep
The engine in the article had some fancy work done on the bottom end. The topend where horsepower (and torque
) are made was severly limited; stock carb, stock intake, stock heads. They got to choose a cam. Might have been a custom grind or something off their shelf. The thing made over 160hp more than the 302 you keep referring to.
.Anyone including you would be a fool to use the old heads, when these new Vortecs severely outflow them. These new Vortec heads outflow the older Vortecs. The proof is there, 632hp from a cheap set of iron heads.
. Actually, you would have to use a LOT of octane booster to even get it to run. HOWEVER, the average C3 Vette is much closer to a NASCAR cup engine than you realize. Single 4 bbl Holley carb, single 4 bbl manifold, solid lifter FLAT TAPPET cam, mechanical fuel pump, etc.Actually, the parts that cost the MOST money to build, and are worth their weight in gold, are the cylinder heads. NASCAR teams sped a LOT of money getting the absolute TOP performance out of the heads.
Yeah that magazine engine made big HP. BUT AT WHAT COST????
You are too quick to disparage the old heads and jump on these new ones. Those old heads STILL make tons of HP and flow VERY well.
The "trick" to getting that horsepower is compression. If you are farting around with 9 or 10 to one, you just ain't gonna make it.
Dep
Pretty neat!!!
Dep
And your clunky old SBC close to a late sb2.2 engine? come on, you must be joking. They are so far apart, especially when it comes to the valve train and the heads. For instance the valve train, apart from using shaft mounted rockers let's compare the flat tappet lifters & cam. The nascar stuff is far more advanced than what your standard SBC has, special cam cores made from special alloys with hardened and inlaid lobe faves, oversize zero radius tappets, cam oilers and major block modifications and for what...to get the maximum out of them and have them last the 500 or so miles. If they were allowed to run rollers they would. Just because something puts out good numbers on a race engine doesn't mean it's the ultimate, especially when there are rules & restrictions, and 500 miles..that ain't a whole lot
Compare apples to apples, to get that kind of performance out of your engine w/ a similar valve train that will hold up for many many miles is impossible, if you can do it you need to call a nascar team, they will want to hire you.
the blonde weasel
Compare apples to apples, to get that kind of performance out of your engine w/ a similar valve train that will hold up for many many miles is impossible, if you can do it you need to call a nascar team, they will want to hire you.And I DIDN'T say the NASCAR engines were EXACTLY the same as what we run. I said they were CLOSE. They do have everything I mentioned. Just MORE advanced. Actually, the Busch cars DO run roller cams.
So what "apples" do you want to compare the Vette engine to???
A F1 car? A CART car? An Indy car? A Can Am car? A funnycar or rail?
The answer is no, no, no, no, and no.
500 miles ain't a hell of a lot? Oh right...I'm sure YOUR engine can run at 7000+ RPM for 500 miles
And a newsflash for you. Back in the early 60s Mercury had a commercial and all kinds of ads in Hot Rod magazine. Using 4 Mercury Comets with 289 engines, they ran 100,000 miles at 100 miles per hour.
Impossible for us? I don't think so.
Dep
