Running solid lifters? How often do you adjust the lash?
Old Jun 8, 2005 | 08:53 AM
Custum73's Avatar
Custum73
Default Running solid lifters? How often do you adjust the lash?
Just curious how often folks running solid lifters are adjusting valve lash. Things don't seem to be knocking too bad yet, though I've only owned the car a year and it's always sounded the way it does. A friend of mine said to do it every 6 months. Is it better to be proactive with them or wait until I notice a change in the sound of the engine. Am I worrying too much about nothing?
Old Jun 8, 2005 | 08:57 AM
norvalwilhelm's Avatar
norvalwilhelm
I set mine in the spring when I take the car out of storage and don't touch them until fall when I back the springs off.
Why should they move unless something is going wrong??
Old Jun 8, 2005 | 09:11 AM
CGGorman's Avatar
CGGorman
Up until last weekend I had to adjust them every time I drove it. After adding jam-nuts to the "soup", I've now gone a week without adjustment!
Old Jun 8, 2005 | 10:15 AM
68raggtop's Avatar
68raggtop
I ran all last year on my initial setting. I checked them before I backed them off and nothing had changed at all. I was running the stock nuts. I changed to polylocks only because I got them for almost nothing.
Old Jun 8, 2005 | 11:05 AM
VETDRMS's Avatar
VETDRMS
I usually set mine when it comes out of storage, and sometimes after a lot of racing. With stud girdles, they do not move.
Old Jun 8, 2005 | 05:19 PM
Gordonm's Avatar
Gordonm
I adjust them in the spring. This is the first time in 3 years I have actually had some off. 6 of them were off .004 the rest were good. I check them maybe once in the summer and they are always dead on.
Old Jun 8, 2005 | 06:23 PM
jpatrick636's Avatar
jpatrick636
I also do mine in the spring. They never need much.
Old Jun 8, 2005 | 06:26 PM
Corey_68's Avatar
Corey_68
With Poly locks, I check them once a year and if they are off it's not by much.
Old Jun 8, 2005 | 10:59 PM
Brettmc's Avatar
Brettmc
I've had a solid for 9 months and haven't checked it since right after break-in :o
Brett
Old Jun 8, 2005 | 11:35 PM
ZL1powr's Avatar
ZL1powr
I check mine every 3000 miles when I change the oil. Can't remember the last time the adjustment changed.
Old Jun 8, 2005 | 11:44 PM
SSDriver's Avatar
SSDriver
Anyone have a summit part # for the polylocks? Thanks
-William
Old Jun 9, 2005 | 08:27 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
When you install a solid cam, especially when you get into the stuff with the little wheels on them you gotta check them frequently at first. Each engine is different but what usually happens is you will get some initial wear that will require adjustments. After a period of time/miles this should settle down ( or you have a more serious probelm ) to where you can adjust them a couple of times year.
A solid roller with roller rockers I would be checking more often than a solid flat tappet with stamped steel rockers.
Old Jun 9, 2005 | 08:34 AM
Vesa's Avatar
Vesa
Once a year - mine tend not to move much...
To Running solid lifters? How often do you adjust the lash?
