Aftermarket cam question
Old Jun 8, 2005 | 09:07 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default Aftermarket cam question
How *big* of a difference would an aftermarket cam make in low end torque/power? I have stock 882 heads, rams horns exhaust manifolds, edelbrock performer intake. 4spd close ratio BW transmission.
NO, im not replacing any of the above items till they break. NO, Im not going to remove engine bore/stroke etc.
Just a simple question about a cam swap and what power gains could be found by this ONE mod (lifters obviously included).
I'd prefer to stay with hydraulic, I'll never see really high RPMs as this is basically a weekend driver car. Which is why Im interested in lower rpm power band.
Thanks for any input.
Old Jun 8, 2005 | 09:34 AM
page62's Avatar
page62
A cam will certainly help. Something along the lines of an XE268 or similar. But the heads still have those wheezy 76cc chambers. And we won't even talk about compression ratio.
You could do both cam and heads for about 1200 bucks -- perhaps less -- if it's a DIY project.
Old Jun 8, 2005 | 11:22 AM
ruby76's Avatar
ruby76
Yeah,yeah, I know all about the 76cc heads, but the truth is, it runs fine, has pretty decent power etc. I am just curious on what gains can be had from a simple cam/lifter swap, while maintaining vacuum etc. Heck, for all I know I might already have an aftermarket cam in the engine. I know if it does have one it isn't too big cause it idles nice.
I figured some of the gear heads or numbers guys would maybe have a figure or two.
Old Jun 8, 2005 | 11:23 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
the cam can definitely wake up the car! the new one I put in mine before CI definitely did!
Old Jun 8, 2005 | 11:26 AM
ruby76's Avatar
ruby76
which cam upgrade did you go with?
My neighbor has a "RV cam" in his 69 chevy truck and it runs real strong. Otherwise a very stock 350 engine. From what I've heard, the "RV Cam" is just a term for a cam made to give you low end power. That's the kind of power you can "feel" and probably what i'd want. But I don't know what numbers, duration, lift etc constitute a cam of that description.
I guess I'd need to take my cam to a machine shop to determine it's numbers right?
To Aftermarket cam question
