BBC Fuel Pump Rod Install ?
Old Jun 11, 2005 | 10:18 AM
Hvymtlc5's Avatar
Hvymtlc5
Default BBC Fuel Pump Rod Install ?
Does the fuel pump rod need to be installed with the timing cover off or can it be slid in through the opening the fuel pump bolts into? Is the rod driven by a an excentric on the crank? Already put the cover and dampner back on................................
Old Jun 11, 2005 | 10:22 AM
shadetreeperf's Avatar
shadetreeperf
It can be installed with the timing cover on, through the plug that is underneath the fuel pump.
KC
Old Jun 11, 2005 | 10:24 AM
rponfick's Avatar
rponfick
Fuel pump rod mounts through fuel pump mounting hole, or plugged hole just under pump mount. Grease it up with heavy grease and it may stay in place without having to hold it up. Mine did. Rod is activated by lump on cam. Try to turn over engine so you are on cam low spot to avoid fighting pump arm pressure when trying to bolt pump on.
Old Jun 11, 2005 | 10:28 AM
Hvymtlc5's Avatar
Hvymtlc5
Great - thanks for the quick reply..back to the garage
To BBC Fuel Pump Rod Install ?
