MSD question
Old Jun 13, 2005 | 06:57 PM
rw131136's Avatar
rw131136
Cruising
Default MSD question
Installed an MSD 6A on '76 L48 auto. The car cruises nicely and WOT is improved BUT there is now a hesitation at take off unless I mash the pedal. Also before MSD install, the car would consistently chirp the tires at 1/2 throttle from a standing start. Now nothing. I certainly didn't expect to lose low RPM power with this ignition. I've never run into anything like this before. Installed MSD on an old Fairlane years ago and did not experience this problem. Any suggestions?
Old Jun 13, 2005 | 07:17 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
1 plug gap?
2. what else did you do?
Old Jun 13, 2005 | 07:23 PM
rw131136's Avatar
rw131136
Cruising
No other changes were made.
Old Jun 13, 2005 | 07:24 PM
norvalwilhelm's Avatar
norvalwilhelm
No way the MSD took away power. I believe at low rpm the MSD fires twice and as for 1/2 throttle chirping the tires again the MSD wouldn't loose power. Something else has changed. As for spark plug gap I just leave it the same as stock.
Old Jun 13, 2005 | 07:29 PM
rw131136's Avatar
rw131136
Cruising
Sparks plugs were not removed or regapped. Nothing was changed. I expected low RPM improvement but for some reason this has not been the case.
Old Jun 13, 2005 | 07:37 PM
norvalwilhelm
A MSD will not increase your power over a good normal system. If you stock system is working good you will not notice a change with the MSD. A spark is a spark if it ignites the mixture. The MSD just garantees a health spark and in the case of the 6AL it acts as a rev limiter.
Old Jun 13, 2005 | 08:06 PM
rw131136's Avatar
rw131136
Cruising
"A spark is a spark if it ignites the mixture."
Good point - IF it ignites the mixture. Standard induction ignition sparks are longer in duration yet less intense than a CD generated spark.
The mulitple spark function is supposed to make up for the shorter duration spark of a CD and that is why I can't figure out why I'm getting these kind of results.
I wrote MSD through their web site. Hopefully they can provide some assistance. If not I'll just take the thing off. 30 years ago I didn't mind giving up some bottom end power for more high RPM power, but now I just want a nice responsive street motor.
Old Jun 13, 2005 | 08:57 PM
waterplay's Avatar
waterplay
when installing an MSD it is possible to inadvertently bump the distributor and adjust the timing if only a few degrees. This will and can cause the symptoms that you are describing. Try to advance the timing 2 degrees at a time and see if the problem clears up. Use your head and don’t advance to far though. no more than 6 or 8 degrees past stock.
Old Jun 13, 2005 | 09:00 PM
litevette's Avatar
litevette
You may have a defective product.
Old Jun 13, 2005 | 09:06 PM
waterplay's Avatar
waterplay
No, a defective product is to easy of a fix lets take the whole thing appart first. Way more fun too.
Old Jun 14, 2005 | 09:02 AM
CGGorman's Avatar
CGGorman
I have a digital 6, so I may be barking up the wrong tree. On mine, there are controls for "start retard" It can retard timing 20 degrees below 800 rpm. Any chance your idle is below 800 and your MSD is retarding the timing?
Old Jun 14, 2005 | 09:14 AM
gerry72's Avatar
gerry72
Make sure you wired to coil's polarity correctly. If you reverse polarity it can cause the sort of problems you are having. Very easy to make this mistake.
Old Jun 14, 2005 | 01:38 PM
LOTAHP's Avatar
LOTAHP
Change plug gap to .045 and advance the timing 1 or 2 degrees. That should solve your problem.
In 1977 (close to when MSD first came out), I put a 6A box in my stock '71 Z-28 w/LT-1. I was one of the only mods that I actually felt a difference (for the better) right away. It was a much better pedal response.
Old Jun 14, 2005 | 01:39 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Peon all these suggestions. Disconnect the dang thing and see how it runs WITHOUT IT!!!!
Dep
Old Jun 14, 2005 | 05:19 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
High power ignitions can often cause an ignition weakness elsewhere to get worse. Check cap, rotor, and spark plug wires.
rob
Old Jun 14, 2005 | 06:04 PM
rw131136's Avatar
rw131136
Cruising
I checked the timing and it had not changed. Dist cap and rotor were replaced about a month ago. Wires are Moroso Blue Max. Plugs are gapped at factory spec .045
I think I'm going to put the HEI back in. If the problem goes away I'll know it's the box.
Thanks for all your suggestions
Old Jun 14, 2005 | 06:39 PM
DJ Dep's Avatar
DJ Dep
Attaboy!!!!
Dep
Old Jun 15, 2005 | 07:21 PM
rw131136's Avatar
rw131136
Cruising
HEI is back in and the low RPM power has returned with no more hesitation or stumble on take off
I guess this was an expensive lesson learned. The HEI isn't as weak as all the aftermarket ignition companies would have us believe.
Old Jun 15, 2005 | 08:21 PM
427V8's Avatar
427V8
HEI is a fine system unless you want to run high RPM. then they start to loose it. But an after market module can fix that.
If I were to do it again I would use a modded HEI...
To MSD question
