Pinging under load
Old Jun 15, 2005 | 10:14 AM
rexx78's Avatar
rexx78
Default Pinging under load
I have some pinging at low rpm's under load. The timing has been set to 36* BTDC at 3000 rpm for a while with no detonation, but I have done several changes to the Q-Jet since then. The last few changes I made were:
1: lowered float level
2: changed power piston spring
3: adjusted idle air screws
4: replaced needle and seat with high flow one
I am going to trouble shoot tonight, I just wanted to get an idea where to start.
I have an adjustable vacuum control unit that I am planning on putting in. This may help right?
Old Jun 15, 2005 | 10:35 AM
flood's Avatar
flood
Whats your setup?
Old Jun 15, 2005 | 11:04 AM
rexx78's Avatar
rexx78
I guess that's important. :o
78 vette with 400 ci, 462 heads, XE 262 cam, performer intake, stock distributor, new ignition components (cap, coil, wires, coil, module, etc.) new mechanical advance with the light springs, 79 L-82 Q-jet with "68" jets and "40" rods (as measured with calipers since they are not stamped). 4 speed and 3.70 rear end.
Old Jun 15, 2005 | 11:12 AM
gerry72's Avatar
gerry72
You might be a wee bit on the lean side due to lower the float. Float adjustments are a good way to make slight changes, lean or rich, to the A/F ratio.
It could also be your primary spring if it's holding down the piston for your load. If you went to a heavier spring, you should be fine since this provides earlier enrichment.
It too could be your idle mixture adjustment since idle and transition circuits contribute to the total mixture. Not a lot but some.
And it could be nothing more than the conditions you initially tuned it to no longer exist. Higher underhood air temps and such.
Old Jun 15, 2005 | 11:14 AM
vettfixr's Avatar
vettfixr
From your description of your mods it looks like the springs in the distributor may be too light making the mechanical advance come in too soon. It could also be a vacuum advance that is pulling in too many degrees of advance. With most performance ignition curves the vacuum can should be replaced with one that gives only about 10 to 12 degrees of advance as opposed to the typical 18 to 22 degrees that a stock can gives. First try heavier springs. If that doesn't cure it try running with the vacuum advance disconnected. If the problem goes away check Lars paper for the correct vacuum advance can.
Old Jun 15, 2005 | 04:59 PM
NHvette's Avatar
NHvette
Well, it sounds like he has the ignition curve pushed to the wall,
which is not a bad thing. Also, sounds like it was working well
for some time - until the carb changes.
So, I'd guess that the most likely culprit would be the lowered
float level - giving a leaner (and hotter burning) mixture.
backing off thye timing a few degrees couldn't hurt. 36 is a bit aggresive.
Old Jun 15, 2005 | 08:37 PM
stingr69's Avatar
stingr69
I made a few assumptions and came up with about 11:1 compression with the 262 cam?!? Then you lean it out, with soft advance springs. Sounds like you are probably over the limit on dynamic compression. This one could be difficult to tune out.
Fatten it back up, install some stiffer advance springs and see if it helps. You might want to run the numbers on the DCR as I would be looking there first. I would run it for you but I do not have the cam seat to seat timing numbers.
-Mark.
Old Jun 15, 2005 | 10:39 PM
rexx78's Avatar
rexx78
Thanks for all the replies.
I will raise the float first to 0.400, I am getting pretty quick in taking off the top of the carb. I will then try some stiffer advance springs.
Stingr 69: I think 11:1 is a bit high, I was thinking more like 9.5:1 or so but I could be wrong.
To Pinging under load
