Carb Help Please
Old Jun 15, 2005 | 11:05 AM
Mickman's Avatar
Mickman
Default Carb Help Please
Hi guys,
I am going to try to change the carbeurater on my dads corvette (its a 75) for him, while he is away at work for the week. The one that is on it right now has a fuel leak, and I have another one now that has just been rebuilt. Is there anyone here that could recommend a website that has something that could walk me through how to change it. Any help would be greatly appreaciated.
Old Jun 15, 2005 | 11:21 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Its' not really that big of a deal.
The Quadrajet has 4 main bolts securing it to the manifold. You will probably want to get some tape and label where the vacuum hoses go. Be careful with the electric choke connector; on older cars they are brittle from the heat and will break.
You will want to put a backup wrench on the main fuel inlet when you take the fuel line off. And you should use a line wrench to bust that loose. Not necessary all of the time, but they can be tight and a regular wrench can round off the fitting. You will probably need the same thing on the rear of it for the brake booster line.
Be careful when pulling the clips from the throttle cable. They can easily become a "OH ****, where the hell did that go?" when you take them off.
Just take your time, take notes and you will be fine.
Old Jun 15, 2005 | 11:28 AM
Mickman's Avatar
Mickman
Thanks, I hope I'll be fine, I've never done it before, and I'm only 15.
Old Jun 15, 2005 | 12:09 PM
comp's Avatar
comp
where is the leak ???
Old Jun 15, 2005 | 12:28 PM
Mickman's Avatar
Mickman
Not sure.
Old Jun 15, 2005 | 05:28 PM
comp's Avatar
comp
Originally Posted by Mickman
Not sure.
i'd find the leak first,, may just be screw loose
Old Jun 15, 2005 | 07:11 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
If ya have access to a digital camera, take plenty of pic! makes things way easier when you try to put things back together!
Old Jun 15, 2005 | 08:46 PM
nitronick's Avatar
nitronick
If this is a QuadraJet, I am trying to figure out what screw could be loose that would cause a fuel leak....
Old Jun 15, 2005 | 11:05 PM
chris75stingray's Avatar
chris75stingray
there are plenty of screws that hold the carb together.its probably an accelerator pump.
Old Jun 15, 2005 | 11:34 PM
SteveG75's Avatar
SteveG75
Naw, probably the well plugs. Remove carb, drain it, dry real well, JB Weld over the plugs, reinstall.
Be careful with rebuilt carbs. They are rarely jetted correctly for your application and in fact some are completely screwed up. Saw this in person with several carbs at the recent "Tuning For Beer" stop in NE>
Old Jun 15, 2005 | 11:49 PM
evalu8r's Avatar
evalu8r
Yeah, those rebuilds are a pain. I'm still wrenching on the one that came with my recently purchased vette. I keep eyeballing the hammer on the work bench.
Chris
Old Jun 16, 2005 | 08:42 AM
Boofers's Avatar
Boofers
Good for you for attempting it. At no point rush anything.
Don't adjust anything on the old carb - if the new carb has problems you want to be able to put the original carb back on and have the engine run as well as it did before you started this project.
How do you know the carb is a leaking fuel? Did you look in the intake after the car sat overnight and see wetness? If so you have to remember that the wet fuel you see in the intake may be the accerator pump shot you get when you open the throttle blades.
If you & your dad need to fine tune the rebuilt carb once you get it installed here are some helpful links.
QJet troubleshooting by Lars
QJet tuning by Lars
QJet exploded view
Old Jun 16, 2005 | 10:47 AM
nitronick's Avatar
nitronick
Yeah, there are plenty of screws on a Quad. But exactly which one, if loose, would cause a fuel leak?
None that I can think of....
Perhaps you mean a fuel line.
A lot depends on the rebuilder.
Putting in a kit is not rebuilding a carburetor. Neither is tuning one. Remanufacturing a carburetor is bringing the carb back to factory specs.
Old Jun 16, 2005 | 11:05 AM
Mickman's Avatar
Mickman
Thanks for all the advice guys. Right now, the car has just been fixed after sitting on blocks for 15 years. We have 3 carbs( 2 quadrajets, 1 holley), all of them have something wrong with them. The quadrajet that is on the car now either has a vacuum leak, or a fuel leak im not sure. Right now it is adjusted enough so I can move it in and out of the garage, but it does not idle properly, and stalls alot. I am hoping with the new carb on, things will be better. My dad is the one that has all the knowladge about it, I'm just trying to do something nice for him and fix it while he is away at work for the week. I just dont want to end up doing damage or something, I am only 15 years old and do not have alot of knowledge about this. I have a general idea, but I'm not completly sure. Right now everything is on hold because of the carb. We need to adjust the timing and such and we need a good, working carb to do so.
Old Jun 16, 2005 | 11:34 AM
scotty13's Avatar
scotty13
if it has been sitting for that long, chances are that alot of the origional gaskets and rubber seals in the carburator are long gone. If gas has been sitting in the tank for that long the tank will need to be drained. After you get the tank drained with fresh gas it usually take a little running, although probally not up to par with how you want it to run to, losten things up again. Have fun, you will definitly learn by both reading about how things work and just tinkering with them.
Old Jun 16, 2005 | 12:13 PM
flood's Avatar
flood
My son (if I ever have one) won't be allowed to work on my Vette unless Im around. He must trust you?
Old Jun 16, 2005 | 12:28 PM
Mickman's Avatar
Mickman
scotty13, the carb that is on the car now is already rebuilt, but its just the vacuum/gas leak that is the problem with it. All the gaskets and such were replaced already during the rebuilt.
Old Jun 16, 2005 | 12:40 PM
NHvette's Avatar
NHvette
Nice Father's Day present - unless things go bad.
Just don't mess with the carb that (kinda) works now.
Actually - per Lars - 90% of carb problems are actually ignition problems.
Maybe not the case for yours, but I'd try to get the timing
all set up before moving on to curing carb issues. This is the
way to do it. If the carb allows the engine to run - set the timing up first.
Your homework: download and read all the carb/timing/distributor
papers by Lars at Corvettefaq.com
Next: get Dad to read them, too.
especially How to Set Timing and Quadrajet Tuning
Link: http://www.corvettefaq.com/lars.asp
Old Jun 16, 2005 | 12:54 PM
Mickman's Avatar
Mickman
NHvette,Yes, we have already set the timing before but it still does not work properly. and in regards to the other carb, That was my plan to leave it alone so that if the new one doesnt work, i can always put on the old one, and still be able to run it.
To Carb Help Please
