FlowTech Headers & Flowmaster Mufflers?
Old Jun 15, 2005 | 07:03 PM
smthnpls's Avatar
smthnpls
Default FlowTech Headers & Flowmaster Mufflers?
I was just about to purchase a set of ceramic coated FlowTech headers from Summit. I was looking to match them up with Flowmaster mufflers and doing a true dual exhaust. But after reading other threads about extreme noise in the interior.. I'm questioning this setup. I love the sound of the flowmasters (that throaty/tinny sound) on other cars. My brother has a 70 ss chevelle big 454 that sounds awesome! Would another muffler be better for my application?
1979 Black/Black T-Top, 350, 30 over, Melling (aggressive) cam, TH350, Performer alum intake, Q-Jet carb, stock heads.
Thanks,
Paul
Old Jun 15, 2005 | 08:34 PM
Gordonm's Avatar
Gordonm
Depends on which Flowmasters you get. I have the Delta Flow 50s on mine and it is not bad at all. I am running an H pipe also. It will sound different than a Chevelle due to the pipes after the mufflers on the Chevelle.
Old Jun 15, 2005 | 09:28 PM
seventyeightcorvette's Avatar
Thanks,
Paul
Yea, I got Dynomax headers with Magnaflow mufflers. It is louder than I wanted inside but not terrible. I still want to quiet it down though. I am going to install Fatmat (double layer in back) and if I have room I am going to put a layer of Frost king on top of that, then my carpet. I am courious to see how well it works.
Old Jun 16, 2005 | 05:23 PM
smthnpls's Avatar
smthnpls
I'm looking to doing an H pipe also. I will be having a muffler shop make the pipes, as I don't think there is a complete aftermarket header back system with an H.
Are the DeltaFlow 50's the quieter mufflers?
Thanks,
Paul
Old Jun 16, 2005 | 05:42 PM
JRS 73's Avatar
JRS 73
I just had a new exhaust system installed in my 73 about 3 weeks ago. I had them install Magnaflow mufflers, and yes they are loud when you are accelerating, but once you are cruising it is fairly quiet in the interior of the car. I wanted to retain that muscle car sound.
Old Jun 16, 2005 | 07:21 PM
25th silverbullet's Avatar
25th silverbullet
St. Jude Donor '05-'07
I put a true dual with flowmaster 40's on my '78 stroker and it sounds great. I do wish I had gone to the super 40's, but it is loud enough as is. There is a little bit of sound reverb in the car at certain RPM, but I kind of like it...
Old Jun 16, 2005 | 07:31 PM
smthnpls's Avatar
smthnpls
thanks for your input....
So..are the 40's or 50's louder? Also, Which headers do you have? I wish there was a way to hear all the different combinations...
Paul
Old Jun 16, 2005 | 07:54 PM
Gordonm's Avatar
Gordonm
The 40s are louder than the 50s for sure. I have heard many 40s and they were a bit to loud for driving. They are calling every officer around. The 50s are quite loud at 6500 rpm but nice at cruising speed. I have had many compliments on my exhaust system. Some love the 40s and some love the 50s. Exhaust is a matter of personal taste.
Old Jun 17, 2005 | 11:25 AM
captainmorgan's Avatar
captainmorgan
I am in the process on installing magnaflows on my '77.
Do you have an H pipe installed?
Old Jun 17, 2005 | 12:24 PM
oregonsharkman's Avatar
oregonsharkman
Thanks,
Paul
That is my exact exhaust setup:
Flowtech ceramic coated headers
2 1/2" custom exhaust with no crossover
Flowmaster 40's
They are actually not as loud as I thought, not like glasspacks or anything, There is some resonance at low mid rpm cruise but my car is not a daily driver so I always enjoy it.
Here is a sound clip of the flowtech/40's with my 440hp 383 stroker:
http://home.comcast.net/~donjgraham/flowmastervette.wav
Old Jun 18, 2005 | 01:08 PM
flynhi's Avatar
flynhi
An X pipe will reduce sound levels about 10 dB and increase HP. They are used by all NASCAR teams.
Do the FlowTech headers live up to their advertising on increased torque?
Old Jun 18, 2005 | 03:34 PM
JRS 73's Avatar
JRS 73
No I don't. I wanted one, but for whatever reason the muffler shop didn't install it. I used to have a bit of resonance inside the car with the old exhaust system, but none with the magnaflows.
Old Jun 20, 2005 | 12:32 PM
smthnpls's Avatar
smthnpls
Flowmaster 40's
WOW...awesome sound clip. Sounds like a powerful motor.
now I can't wait to do mine.........
thanks,
Paul
Old Jun 20, 2005 | 12:45 PM
munday's Avatar
munday
The summit brand mufflers outflow the flowmasters but a significant amount. Flowmasters barely outflow oem. I have the data sheet around here somewhere if i can find I will post. oem is something like 285 cfm and summit is 325-45 I think. Dynomax bullets and borla xr-1s' were in the 2600 cfm range.
Old Jun 20, 2005 | 05:35 PM
Gordonm's Avatar
Gordonm
I've read this before also. I can tell you it is a bunch of random numbers. I'll put a Flowmaster of equal size up against about anything out there and it will produce as much HP as the next. Some of the flow numbers they quote are better than a straight pipe. How can that be. I'm certainly not an ad for Flowmaster but those numbers are false. They gat a bad rap. Some like them some hate them.
Old Jun 20, 2005 | 06:53 PM
smthnpls's Avatar
smthnpls
I don't know how much difference I would notice between Summit and Flowmasters. I'm just changing from a stock exhaust to true duals with an "H". I think it will be substantial difference in performance no matter which ones i go with. I've always liked the sound of Flowmasters, thats why I asked about them on a vette.
Anyone out there use the Summit mufflers?
Cheers,
Paul
To FlowTech Headers & Flowmaster Mufflers?
