Electrical death
Old Jun 16, 2005 | 10:23 PM
XShark's Avatar
XShark
Default Electrical death
I was replacing the center console (testing the power windows in my 77)
When I grounded it out, and everything went dark.
Everything. I have zero electrical, except my radio, which is wired directly to the battery.
I must have blown a fuse, or something.
Where to start looking?
Old Jun 16, 2005 | 10:41 PM
wombvette's Avatar
wombvette
Probably the fuseable link at the starter connections.
Old Jun 16, 2005 | 11:42 PM
XShark's Avatar
XShark
Thanks.
Old Jun 17, 2005 | 03:56 PM
XShark's Avatar
XShark
The battery is wired directly to the starter.
I measure 12V across the starter.
Still nothing works.
Have I fried a starter? (would it still show a voltage if it was toast?)
Old Jun 17, 2005 | 05:39 PM
72GACRZR's Avatar
72GACRZR
Not likely. You have melted a fusible link or fuse somewhere, do you have a service manual with a wiring schematic? YOu will have to try to locate where they could be.
Old Jun 17, 2005 | 06:04 PM
BUGGSY1970's Avatar
BUGGSY1970
First look at the fuse box and see if you blew some fuses. If that fails you need to get a wiring diagram and look for the fusible links. A likely one is the hot lead to the starter that would shut down much of the electricity in the car.
Old Jun 17, 2005 | 06:27 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
the fuseable link connects the battery to the Alt. It usually comes from the starter connection and goes to the horn relay.
Old Jun 17, 2005 | 09:26 PM
sjr1971's Avatar
sjr1971
427V8 :: THATS a A.H. Bugeye Sprite circa '60. your driving. This leads me to believe you are acquainted with the Joesph Lucas Electrical Co. Folks ,this man knows electrical problems, if that an English car that 'es drivin. If you have an OPEN to Ground , you will read syst. voltage across the OPEN
Old Jun 20, 2005 | 09:28 AM
XShark's Avatar
XShark
My car has some bubba in it, so its not quite stock.
I have two wires going to the starter. One is the battery cable, and one goes into the cable harness under the brake booster.
I have 12V at the starter. I have 12V at the alternator.
I've checked the fuses under the dash, and they all look fine.
Where should I look next?
Old Jun 20, 2005 | 10:13 AM
rihwoods's Avatar
rihwoods
Not sure,but there could be a circuit breaker involved here...and you should have fusible link to starter....My 78 does...I know,because rats ate the wires once........
Edit- Chiltons shows a fuse link between alternator/starter (red wire) for 76-78.
Old Jun 20, 2005 | 10:05 PM
XShark's Avatar
XShark
Fusible link is OK.
Continuity & voltage checks out.
I have 12V going into the firewall, but nothing at the fusebox under the dash.
Is there another fusible link or larger fuse I could have blown?
Old Jun 20, 2005 | 10:19 PM
wombvette's Avatar
wombvette
Check the main power wire in the firewall connector. It is probably burned or otherwise lost its contact. This is common with C2 cars and sometimes happens with C3s.
Old Jun 21, 2005 | 01:34 AM
mstock's Avatar
mstock
Default linkable fuses.
If I remember right there are some on the drivers side, next to the fender, below the brake booster.
Old Jun 21, 2005 | 01:51 AM
71SoCal's Avatar
71SoCal
You might have to pull the fuse panel away from the wall to inspect it.
I would have expected your power window circuit to be protected, blowing it's own fuse rather than possibly burning a primary feed wire up???
There should be a big fat red wire running from outside of the firewall in through the dash main harness. Inside that harness, the red will split and one path will go to the fuse panel to run your "battery" components.
Make sure the entire fuse panel is dead, checking both sides of the fuse.
You can always run a temporary hot wire to the fuse panel to test the theory...just be careful if you do.
Good luck...
Old Jun 21, 2005 | 07:43 PM
XShark's Avatar
XShark
I fixed it
So what was it?
The fuse block screwed into the firewall was loose.
While fiddling with it today with a coworker, he told me to kill the battery power (we were getting ready to take it off), and I noticed the domelight was on!! He jiggled it and the light flickered.
We went ahead and unscrewed it, and thats when he noticed it was not tight. I WD-40'd the connectors and reinstalled.
Everything works! (except the left power window...it still won't work, I wonder if I fried the switch).
Thanks for all your help. I'm back on the road again!
(but not very far from home, yet)
Old Jun 21, 2005 | 10:37 PM
rihwoods's Avatar
rihwoods
My right side power window once did not come up.I gently hit the area just above the arm rest,and it has worked since.The motor is just below that spot,and I figured it was a loose connection...don't know for sure....
To Electrical death
