79 Engine Bay Wiring - Harnesses
Old Jun 16, 2005 | 11:05 PM
79Cruzer's Avatar
79Cruzer
Default 79 Engine Bay Wiring - Harnesses
I would like to replace the engine bay harnesses. It looks like there are 2 of these connected to the bulkhead connector. Everything seems to be working ok but most of the plastic wire coating on these harnesses are brittle and just a matter of time before electrical problems start cropping up if wires break. My questions are :
1) Are new harnesses readily available?
2) Is there a special tool to get these harnesses out of the bulkhead connector? I don't want to crack the thing open by force things with a screwdriver.
Old Jun 17, 2005 | 12:08 AM
Star79's Avatar
Star79
I can tell you they are definitely available, checked the catalogs of the Big Three and they have various ones priced reasonably for a 79 (<200 for a front lighting harness, also <200 for engine harness).
I'll let someone else answer the second question regarding how to put them on or take them off.
Old Jun 17, 2005 | 01:27 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
1) Yes, Try looking at: http://www.lectriclimited.com
2) It's the "special" per-se. There is a bolt in the middle of those two block connectors that holds both of them in to the front of the fusebox (which is what those blocks plug into at the firewall) . If I remember correctly it takes a 7/16" socket, it is easier to see what you are doing from underneath the car.
When you do change the harness's I would suggest that you go from the firewall and follow each one all the way to the last connector, then work your way back to the firewall disconnecting and labeling each plug as you go. Then install the new harness in reverse order (starting at the firewall working towards the other end) using the old harness as a guide.
I did mine while my engine was out of the car so I had easy access to everything, but it shouldn't be too difficult even with the engine in place. Plan on it taking an afternoon and a 6 pack to get it done.
Old Jun 17, 2005 | 09:42 AM
79Cruzer's Avatar
79Cruzer
Thanks for the info guys. Good advice on installing these. I'll check the various links out. The brittle wiring is something that's been bugging me for awhile so I want to get this done.
To 79 Engine Bay Wiring - Harnesses
