Problems with cam
Old Jun 17, 2005 | 10:26 PM
pastortroy's Avatar
pastortroy
Default Problems with cam
Ok, now I have the Comp cams XS274S with solid lifters in my vette, but with 9.5:1 compression it it's turning out not to be the best cam since I don't have higher compression. Well anyways I used to have the Comp XE268 Cam with Comp hydralic lifters. Around 5,000 RPM I began to have problems where the engine broke up, I believe the hydralics got "pumped up"; this occured even after putting in bigger springs. Anyone running different brand hydralic lifters that work good with this cam? I liked the other cam because it gives you that seat of the pants torque. Can someone give me some advice?
Old Jun 17, 2005 | 10:35 PM
pastortroy's Avatar
pastortroy
forgot to mention the engine is a big block 454
Old Jun 18, 2005 | 12:09 AM
After Shark's Avatar
After Shark
Not to pick on you, but regardless of big or small block, you should always use the cam kit they recommend with the cam. Sounds like you are trying to mix hyd lifters with a solid lifter cam.
Old Jun 18, 2005 | 02:15 AM
Brettmc's Avatar
Brettmc
I've got the 274s in my 468....runs good for me...
Brett
Old Jun 18, 2005 | 05:40 AM
Matt Gruber's Avatar
Matt Gruber
how's the ignition system? not points i hope
plug gap? condition?
Old Jun 18, 2005 | 08:43 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I was gonna say "how's the ignition system? not electronic i hope"
If it's points he can just change to a stiffer spring version like Accel or NAPA makes. Presto...no more bounce.
I agree....you SHOULDN'T be using hydraulic lifters with a solid lifter cam.
Dep
Old Jun 18, 2005 | 09:14 AM
Matt Gruber
any weak ignition system will cause problems
http://community.webtv.net/MATTGRU/BRAKES
middle of page
Old Jun 18, 2005 | 09:59 AM
DJ Dep's Avatar
DJ Dep
middle of page
Lars likes points
Dep
Old Jun 18, 2005 | 10:50 AM
Matt Gruber
Originally Posted by DJ Dep
Lars likes points
Dep
smart man. lots of free beer
Old Jun 18, 2005 | 11:33 AM
DJ Dep's Avatar
DJ Dep
Just yankin' your chain Matt
But I do prefer points. That KISS thing you know
Dep
Old Jun 18, 2005 | 12:37 PM
Matt Gruber
Dep
i sure don't care if u guys use points,
but don't complain MY POWER IS LOW
in 1972 i learned how to make points work well. i doubled up on the spring and used CD ignition.
shifted at 7000 no problem. switch off the CD and it ran 1 sec. slower in the 1/4
KISS isn't always fastest, just simple
Old Jun 18, 2005 | 01:05 PM
DJ Dep's Avatar
DJ Dep
Note I said POINTS with an "S" . I will be using a 1962 dual point distributor with no vacuum advance. Hence, no need for CD
Okay...we hijacked enough here. I'm still wondering if pastortroy
is running hydraulic lifters with a solid lifter cam and roller rockers
Dep
Old Jun 18, 2005 | 01:19 PM
Matt Gruber
dual points
did u see smokey yunicks 8 points distributor
"AN ILL FATED EFFORT TO IMPROVE COIL SATURATION"
see his book, 8 points
you do read books dep?
Old Jun 18, 2005 | 01:26 PM
DJ Dep's Avatar
DJ Dep
dual points
I have a complete library. I use what's worked for me in the past. CD and MSD is fine for street cars that need to burn fuel at low-to-mid RPM. At high RPM they aren't really doing much. The box does give the appearance of a "race car" though
Dep
Old Jun 18, 2005 | 02:31 PM
Matt Gruber
i'll let u read it and report back.
To Problems with cam
