multi point injection
Old Jun 18, 2005 | 08:46 AM
doopsvette's Avatar
doopsvette
Default multi point injection
im putting mpi onto my L81 my question is will converting the stock hei dizzy to "hall effect" mean that i can get rid of computer or will i have to replace the dizzy with another and convert that to "hall effect" to get rid of computer
cheers
Old Jun 18, 2005 | 10:25 AM
zwede's Avatar
zwede
Need more info. What kind of MPI are you installing? Many aftermarket computers work with later model HEI's such as the 81-86 large cap 7-pin HEI or the 87-95 remote coil 8-pin HEI.
"Hall effect" is the type of trigger. HEI is magnetic, not hall effect.
Old Jun 18, 2005 | 11:05 PM
doopsvette's Avatar
doopsvette
going to be fitting edelbrock pro flo 3503
edelbrock send a dizzy conversion kit that enables the hei to work with the system and they call it a hall effect
Old Jun 19, 2005 | 01:30 AM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
Just put the edelbrock mpi on our 66 chevelle in april. just convert your distributor with the kit and plug it in. if your worried about it not working with your dist., mallory makes a dist. specifically for the edelbrock kit. Good luck
To multi point injection
