Carb too small ?
Old Jun 20, 2005 | 12:13 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Once the fuel pressure/volume issue is determined.....it may be time to start playing with PVCR's. You can add a good bit of fuel by opening them up. That way you maintain clean street cruising with little juets and get the fuel you need at WOT.
JIM
Old Jun 20, 2005 | 12:24 AM
Simmo's Avatar
Simmo
Originally Posted by MotorHead
I am using the stock fuel line from the tank.
Might be too small. Im sure you need an absolute minimum of 3/8, my 1970 big block came with that but I think small blocks might have had smaller, especially later ones. Im using 1/2 inch now with an electric pump at back pushing. Can you rig up a rear pump or bigger line for a temporary test. If you are making 150 horsepower more than stock and pulling more g's with better traction, it seems logical that you could be really testing the original factory spcifications.
Anyone out there with expert knowledge on fuel lines?
Old Jun 20, 2005 | 04:03 AM
Matt Gruber's Avatar
Matt Gruber
Originally Posted by Matt Gruber
also remove and discard both brass inlet fuel filters.
Well, this is about the 3rd question/ advice
u have failed to respond to. So i now have the answer to the Question:
ARE YOU A GOOD MECHANIC?
Old Jun 20, 2005 | 08:24 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I don't think Holley 750DP #4779 come with inlet filters, if I recall from a few years ago when I was putting the fuel lines on, one of the first things I checked for.
Old Jun 20, 2005 | 01:22 PM
MotorHead's Avatar
MotorHead
Interestingly enough someone else on the LM-1 forum is having the same problem :
QUOTE>Hi guys.
Was finally tinkering w/the LM-1 today, and made some observations. At idle, the AFR is at 12-12.8. Cruising light about 12-13. Heavy throttle 14-15. I'm too rich at idle and too lean under load right? I need to reverse this setup. If I put bigger jets I think I will worsen the low speed situation. Also, how does one lean out the idle mixture (screws?)
Carb is a 870 vac sec on a 454HO.
Vince
69 CHEVELLE SS
454HO
(8:75:1, rec-port, 211/230 .510/540 roller)
800 DP/GM rec. port highrise
1.75,2.5" Flowmstr/MSD HEI/6AL
M20/C-FORCE DF/3.31<QUOTE
Now the idle and cruise I am not too worried about as you can lean the idle mixture screws , drill small holes in the throttle blades, put a small wire ( 0.005" ) idle-feed restrictor holes or re-jet the primary smaller.
It is the WOT that I am worried about, you would think that giving it a shot of gas the A/F would get richer not leaner.
Old Jun 20, 2005 | 01:36 PM
Matt Gruber
i'd send it back for a refund
Old Jun 20, 2005 | 02:15 PM
jpatrick636's Avatar
jpatrick636
No expertise here, but I just read an article on this topic that seems to fit. I will look for it when I get home.
The heart of the text was that while testing WOT low fuel conditions, it was found that (in condition simular to yours) low fuel in the bowls was the cause. However, what the authors found was that the solution was not to increase the line pressure as they found the needle valve was the real problem. Increasing pressure caused tubulence in the bowl at low levels, causing feed problems. The size of the needle valve is the restricting factor. They cured the problem by lowering the fuel pressure and installing a larger needle valve (available through Holley). This gave them less velocity but more volume into the bowl: which cured their starvation problem.
To me this makes sense as, in hydronics, we don't increase volume with pressure. We do it with line size. Yes, pressure increase will give you some volume through increased velocity, but your not feeding an injector, your just filling a bowl and your goal is a steady volume.
Something to think about.
