Power Window Relay Switch
Old Jun 20, 2005 | 07:39 PM
BerniesVette's Avatar
BerniesVette
Default Power Window Relay Switch
I remember seeing a thread a while back about someone replacing the power relay switch to improve the window operation. I am working on the power windows on my '79 and I can't find a relay for the power windows in the assembly manual. Is there really a relay switch for the windows?
Bernie
Old Jun 20, 2005 | 08:35 PM
onaqwst's Avatar
onaqwst
i had one in my 77...not sure on yours but it might be located under the shifter console.... had three 12gauge wires into it..... i just took mine out and wired it to the battery with a 30amp fuse.... i needed it to be able to work with the car off...my alarm function/no handles.....
b
Old Jun 20, 2005 | 09:41 PM
BerniesVette
Thanks for the info. I may want to do that anyway or replace the harness to get better current flow.
Bernie
Old Jun 20, 2005 | 11:12 PM
CGGorman's Avatar
CGGorman
On my 68, it right under the radio/heater controls. You'll have to remove the lower console to get it, I think. There are two: one for the windows, and one for the ?(crap, I forgot). There is also a breaker on the firewall beside the brake master cylinder. It's little and kinda hard to see.
To Power Window Relay Switch
