1968 Steering wheel Horn Button Removal
Old Jun 21, 2005 | 02:26 PM
1968vert's Avatar
1968vert
6th Gear
Default 1968 Steering wheel Horn Button Removal
OK...,this is probably one for the stupid question catagory. How do I remove the horn button/cover? I don't want to break it.
Larry
Houston, TX
Old Jun 21, 2005 | 02:28 PM
pws69's Avatar
pws69
Larry
Houston, TX
PULL!!
Old Jun 21, 2005 | 03:06 PM
CruisinCO's Avatar
CruisinCO
It is notched so twist a little then pull...It isn't connected to anything so you won't break anything underneath.
Old Jun 21, 2005 | 03:29 PM
CGGorman's Avatar
CGGorman
No twisting necessary...
I had my upper column spread all over the garage last weekend.
Old Jun 18, 2012 | 11:29 PM
Baddog67's Avatar
Baddog67
Cruising
I have been pulling with no success, does it really take an excessive amount of force?
Old Jun 19, 2012 | 01:32 AM
azza2u's Avatar
azza2u
It shouldn't take too much force, then again depends on how long its been on there. This is a pic of what it looks like with it off. You can see the 9 tabs with the indents around the outside of it that fit into a matching groove on a ring on the underside of the button itself.
Best bet is to try to lever it up a bit to have a peek through the gap to find where one of the 3 screws are as per the pic. Levering from one of those points should have the least resistence.
Old Jun 19, 2012 | 06:57 AM
Jim Shea's Avatar
Jim Shea
You will note that the horn cap assembly is constructed of three seperate parts. The cap itself, the emblem, and the retainer. There are three small diecast posts on the cap. They extend down through the plastic emblem and through the metal retainer. The tips of the posts are spun over holding all three parts together.
It is the metal retainer that snaps into the metal upper horn contact. If you just yank on the cap itself, you may break the tips of the posts and you could end up with three seperate parts in your hand.
You want to take a small screwdriver blade and reach under the horn cap so that you are prying between the retainer and the horn contact. That way you are not placing any stress on the three posts holding everything together.
Once you have the cap assembly removed, you may even want to dab a small amount of JBWeld on the tips of the posts to make the whole connection more secure.
Jim
Old Jun 19, 2012 | 07:14 AM
Baddog67's Avatar
Baddog67
Cruising
Thank you, while I am off to work now, I will try this weekend.
I really appreciate the prompt answer.
Wishing youbwell, and Ill keep you posted as to the progress......
Old Jun 19, 2012 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by CGGorman
...No twisting necessary...
Old Jun 19, 2012 | 02:24 PM
nelson007's Avatar
nelson007
Where did you get the drawing of the steering column?
Old Jun 19, 2012 | 02:39 PM
Jim Shea's Avatar
Jim Shea
The steering wheel and horn parts drawing came from the 1971 Chevrolet Chassis Service Manual, Steering 9-6. A lot of the shop manuals just show the cap assembly and not the three parts blowup style.
Jim
To 1968 Steering wheel Horn Button Removal
