Stupid carb question.
Old Jun 21, 2005 | 06:54 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
Default Stupid carb question.
I am replacing the Quadrajet on my 77. With the new setup, I need a 750. Now to the stupid question. The car is not here, so I can't look at it. Does it have a manual (vacuum) choke, or an electric choke?
Old Jun 21, 2005 | 07:00 PM
JustinGJ's Avatar
JustinGJ
Electric
Old Jun 21, 2005 | 07:16 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
Originally Posted by JustinGJ
Electric
Thanks.. I couldn't remember.. I was thinking it had a vacuum choke.. Glad I didn't go from memory..
Old Jun 21, 2005 | 07:23 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
It won't be electric unless someone converted it. It should have a tube coming from the intake manifold that conducts heat.
Old Jun 21, 2005 | 07:33 PM
JustinGJ's Avatar
JustinGJ
Well, it's not a manual choke anyways. Really you need to modify either way, either run a power wire or a cable, depending on how stock you want it to act.
Old Jun 21, 2005 | 08:01 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
That sounds more familiar. I better confirm this before I make any purchases.
Old Jun 21, 2005 | 08:07 PM
The_Dude's Avatar
The_Dude
It doesn't really matter unless you're replacing with stock. Go with an electric choke. It's a simple conversion.
Old Jun 21, 2005 | 08:21 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
10-4.. After doing a little research, what I was calling vacuum is a hot air choke, and that will not work with my intake manifold, anyway.
Thanks for the replies, gentlemen.
Old Jun 21, 2005 | 10:24 PM
jeaux's Avatar
jeaux
What carb you going with a Holley street avenger?
To Stupid carb question.
