Time to put the engine back in
Old Jun 21, 2005 | 08:58 PM
swallace's Avatar
swallace
Default Time to put the engine back in
I took them out seperate but can I put them back in together ?
73 350 with Muncie 4sp
Old Jun 21, 2005 | 09:52 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
We put mine back in together. I also had a 350 with a muncie.
My advice is to put as much on the engine out of the car as you can. Don't go crazy but you can add the exhaust manifolds, spark plug leads, heat shield and the spark plugs. Leave the distributor as it gets in the way at the firewall. Also leave off the fan. Install the water pump though. I put the shifter on the muncie and also adjusted that out of the car. Got it spot on and no busted knuckles. I did not have everything on my engine but it would have fit easily.
Get an engine leveller and a good hoist. You need to wiggle it in.
We had to roll the car back and forward a little, change the engine angle with the leveler and lower the hoist.
We even had to let air out of the tires to clear the fibreglass at the front of the hood. The radiator, shroud and support were out of the car.
It took us about 45 minutes to slowly work it in to the car.
Old Jun 22, 2005 | 07:13 PM
71SoCal's Avatar
71SoCal
Wow!!! Stingry, that is one clean car! I would love for my car to be that clean...but I'd probably have to sell a kidney to do it!
Way cool...
Old Jun 22, 2005 | 07:28 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I did.
Old Jun 22, 2005 | 07:29 PM
Empatho's Avatar
Empatho
clean car
Old Jun 22, 2005 | 08:38 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Len. That big freakin motor didn't fit in there. You just posed that picture and then put a mouse in!!!
Dep
Old Jun 22, 2005 | 08:44 PM
dennis's Avatar
dennis
Took my 70 sb out seperately because I couldn't remove the welded exhaust. Came out pretty easy. Figured I'd try putting it back with the muncie attached. Went in no problem. Didn't even have the rear off the car off the ground. One thing though, there's no way to install the original shifter prior to the drop.
You guys cheated with with the hurst shifter. I wanted to put one of those in for a few reasons, but that's the best reason of all!!
Old Jun 23, 2005 | 07:49 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Dep
No way I'd go back to a SB. If there is a next time, I'm going UP the engine ladder.
Old Jun 24, 2005 | 09:59 AM
stingry's Avatar
stingry
Way cool...
So far I have had to give up a kidney, an eye and a hand.
If you see a pirate on a dyalysis machine driving a yellow corvette be sure to wave at me!
The engine remove/rebuild/firewall mod/engine bay detail/engine install only took 5 months of weekends to complete!
Next time I am doing what Jughead did. BB or bigger.
Old Jun 24, 2005 | 11:55 AM
Joebio's Avatar
Joebio
Originally Posted by Jughead
I did.
Could your daughter look any more excited!!!
Old Jun 24, 2005 | 12:02 PM
OldSchool's Avatar
OldSchool
Man, I was thinking that same thing.. I've seen that look before!!!!
To Time to put the engine back in
