odometer question
Old Jun 22, 2005 | 09:58 AM
kodaclr's Avatar
kodaclr
Default odometer question
My odemeter stoped working, I am not racking up the miles anymore tach still works and my speed still works, can anyone suggest where I can start looking for a possible problem and fix.
Old Jun 22, 2005 | 10:26 AM
danno12345's Avatar
danno12345
If your SPEEdometer works, and your Odometer does not, I would suspect something broke inside the speedometer assembly. I've always imagined the odometer working off a gear drive from the speedometer or something.
Maybe somebody that knows what they're talking about will reply too...
I do know there are a few places that will rebuild/restore speedometers, maybe it'd be a good idea to call one of them. Off the top of my head, Ecklers & Mid America both offer this.
Hope this helps a bit,
Dan
Old Jun 22, 2005 | 10:29 AM
Hammerhead Fred's Avatar
Hammerhead Fred
What year car are we talking about?
Old Jun 22, 2005 | 11:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The same thing happened in my '68. The fix is a replacement speedo head. You will not need a complete speedometer, but you will need a head. It's not likely you will be able to repair the odo since most of them are essentially irrepairable units done long ago to keep resellers from turning back the mileage on a used car.
Old Jun 22, 2005 | 12:01 PM
Grinchia's Avatar
Grinchia
here's a link to a complete rebuild procedure:
http://www.corvettefaq.com/c3/RebuildSpeedo.htm
Here's one to change only the odometer gear:
http://www.corvettefaq.com/c3/odometer.doc
...which is likely all you need. The advantage of this approach is less dissasembly required, no need to remove the needle, and less likely to mess up calibration (which you CAN'T do yourself, and would need to send out). It CAN be done, I've done it myself. The hardest part is getting the dash out to remove the speedometer so you can work on it.
[edit] I assumed you have the mechanical speedo pickup, which is actually magnetic. If you have a later model C3, then the guts and procedure may be different...early c3s will be as in the links above.
Old Jun 22, 2005 | 12:05 PM
82Vette'ster's Avatar
82Vette'ster
Yes, the year is important.
If the speedo is working then the cables are spinning fine.
Old Jun 22, 2005 | 01:24 PM
kodaclr's Avatar
kodaclr
Thanks, Its a 1969, automatic 350/300
Old Jun 22, 2005 | 01:26 PM
72GACRZR's Avatar
72GACRZR
I read somewhere that early sharks will have problems with the trip odometer switch hanging up and preventing the odometer to work. Have you recently reset your trip odometer? If so you might try resetting it a couple of times to jar it loose.
Old Jun 22, 2005 | 02:26 PM
kodaclr's Avatar
kodaclr
Thanks I'll give that a shot, Sounds easier then pulling dash
Old Jun 23, 2005 | 10:08 AM
kodaclr's Avatar
kodaclr
Last night I went to rest my trip odometer, No reset button. How do I reset?
Old Jun 23, 2005 | 10:24 AM
72GACRZR's Avatar
72GACRZR
On my 72, it's a pull down **** at the bottom of the dash, but if you haven't been using yours, that probably isn't the cause.
To odometer question
