4175 carb question
Old Jun 22, 2005 | 05:16 PM
Randexter's Avatar
Randexter
Default 4175 carb question
ok so the carb is the same style as a 4175, the list number is 6210-3 or 4 im not sure because the airhorn was milled off, its a 650cfm double pumper. my question is what size jets should i have on the secondaires, the carb was converted from the old metering plate style to a metering block and im have no idea where to start. so what jet size would be equal to the stock amount of fuel flow when the carb had the metering plates? i have no idea where to start so any help would be greatly appreciated. if it helps its going on a 350 with a mild cam, headers, intake and msd ignition. thanks
Old Jun 22, 2005 | 05:34 PM
Matt Gruber's Avatar
Matt Gruber
after lots of tuning i ended up .086" Left .078" rt.
thats w/2101 performer
my 4165 6210-3 came w/ .100"/#85 WAY rich
see my homepage
Old Jun 22, 2005 | 06:08 PM
Randexter's Avatar
Randexter
Hey thanks for the help i realy just wanted somwhere to start at so some where between .086 and .078 is where i will start. i run a team g signle plane and I was womdering is it more important to stager your jets on a dual plane then it is on a single plane intake? any way thanks again for the help
Old Jun 22, 2005 | 07:07 PM
Matt Gruber
i'd start w/ .088" Max Jet both, or #78 Holley jets
they say a single plane has less signal to pull fuel.(so i really don't know)
Old Jun 23, 2005 | 11:20 AM
lars's Avatar
lars
Randex -
If you do not have a power valve on the secondary side, run the secondary jetting 8 sizes larger than the primary side and start off with the primary side at the stock size for the carb list number. Do your tuning from there, keeping the 8-size spread when re-jetting.
Lars
Old Jun 23, 2005 | 11:42 AM
Matt Gruber
Originally Posted by lars
Randex -
Lars
60 stock front
that would be a #68 do u want fries with those pistons
Old Jun 23, 2005 | 01:25 PM
lars's Avatar
lars
Just checked the specs: A 6210-3 is not a metering plate carb - it uses a secondary metering block with #83 jets on the sec side. Just realized you're talking spread bore carb, so these can't be jetted with the 8-size spread typical of the square carbs.
Lars
Old Jun 23, 2005 | 03:07 PM
Randexter's Avatar
Randexter
OK thanks guys i guess ill start high as suggested at 88 and work my way down thanks again for all the help
To 4175 carb question
