A Super Electric Radiator Fan Controller!
Old Jun 22, 2005 | 10:46 PM
PhotoVette1's Avatar
PhotoVette1
Default A Super Electric Radiator Fan Controller!
Digital readout--set exact ON temperature and the exact OFF temperature. It's only $49. Built in 16 amp relay. I'm ordering two of them--one for each fan on my dual fan SPAL.
Controller-->
Old Jun 22, 2005 | 11:31 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Keep up posted on how they work
Old Jun 23, 2005 | 08:26 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Need to find an inconspicuous place to mount that.
Keep us posted. Sounds like a good way to double check temp. I just ordered a laser gun from harbor freight to do the same thing. Also good to check brakes.
Old Jun 23, 2005 | 09:17 PM
Gordonm's Avatar
Gordonm
It only controls an 8 or 16 amp relay. Most fans are at least 20 amps.
Old Jun 23, 2005 | 09:29 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I was thinking my relay was a little heavier than 16 amps. Not so sure of 16 but it is for sure bigger than 8 amps. It is a neat piece of equipment though and would probably handle an electric fan in the 16 amp version.
Old Jun 23, 2005 | 10:01 PM
PhotoVette1
My thinking was to use the internal relay to switch a relay close to the fans.
I'm going to mount them in the battery bay.
I wrote to the company that makes'em and they're quite excited--seems they never thought of this market.
It'd be good to switch on transmission cooler fans and as a de-ice control for the evaporator coil.
To A Super Electric Radiator Fan Controller!
