Poll: Any problems with your CC rocker arm self-locking nuts?
I am familiar with two types of r/a nuts: those with "jam type" or "interference" threads like on most stock non-shaft mounted factory stamped steel r/a's and those like I'm using now with a smaller set screw inside the r/a nut that you tighten down with an allen wrench after you set the nut to the desired place.
I have always referred to these latter type as "polylocks" - but is this correct? Is there even another type or have I botched the terms?
BTW, GoFast raised an excellent point if you are not using something like these locking nuts and are relying on interference threads on the nuts - as this will be dependant largely on the very type of thread you have on the stud (a smoother or different profile thread would not interfere or pinch as reliably.)
I like those ARP Perma-loc rocker nuts and can see aquiring a set soon but looks like tall vlv covers required. But i want to give the double nuts a chance to prove themselves. Still have some tappet noise and will monitor for increase. Also may try 3/4 turn tight for pre-load as i'm thinking the Crane Hi-Intensity lifter may be a little soft at idle.
Any noise from your CC Mag rockers?
Thx again. cardo0
This clicking noise sounds like a loose rocker, however I checked them and all are fine. I verified that the pushrods are not hitting the guide plates (no evidence of contact on the rods), I set the valve lash several times..... I thought this noise was caused by a loose header (found three bolts loose) but that wasn't the problem...
This noise is only there when reving the engine up , it's not there at idle or under acceleration. Only when driving steady at roughly 45mph it's very noticeable, as soon as I push the pedal a little more and accelerate the noise is gone
I'll post the result of my rocker arm swap as soon as it's done.
I replaced the stock Comp nuts the first time I had the valve covers off to re-set the lash (solid flat-tappet). There were some that just didn't feel like they were locking as much as the rest when I put them in, but I didn't have any else to use at the time. I bought the cool-nuts to have on hand for the re-setting of the lash.
How much pre-load do u use? I'm set at 1/2 turn tight and considering going to 1 full turn tight just to see what happens. I'll double check but i think 1 full turn is possible without overadjusting.
BTW what kind/mfr of lifter do u have?
Thx again. cardo0
68ragg: That's what we need to hear if youv'e had problems with those CC lock-nuts. Were urs just too easy to turn? Or any of the CC Mag rockers loose/making noise?
Man i had #3exh clacking away so bad the p-rod could hardly reach it. All less than 45 min run time after all brand new vlv train.
Thx for ur input.
Thx again. cardo0
At the time I installed these roller tip rockers I also installed a Edelbrock cam and hydraulic lifter kit (Performer).
I can only hope that this noise goes away when I install the original rockers - I am afraid of a wiped cam lobe or a messed up cam bearing...
I've not seen a polylock but am guessing that it's what we call "Nyloc"? It's like a normal nut but on top there is some extra metal that contains a nylon (or some sort of polyblurb) material. The thread cuts/deforms this when the nut is tightened & it then grips the thread to stop any movement of the nut. Is this what a polylock is, or is it something else?
Post on the rolled vs cut threads is a good point.
I did replace them with the Crane nuts just for piece of mind anyways.
UKPaul, Comp Cams Poly-locks and Crane Kool-nuts are the type with a hex for adjusting lash and a set screw in the top that is tightened against the stud afterwards, to "lock" the nut adjustment in place.
Dave
Last edited by 68raggtop; Jul 11, 2005 at 11:00 AM. Reason: added comment for UKPaul
Red Bad: Ok ur CC lock-nuts sounded like a problem so thats a mark against CC rocker nuts. Good luck with R&R rockers. I think you may have saved me a try at 3/4 turn tight preload. BTW my rockers are 1.6 ratio - may have a significance. How 'bout urs? 1.5? 1.6?
Your situation is similar to mine and i appreciate the input.
Thx for your honesty ragg: I don't know how to count the solid cam's lock nuts since a possible bad set of hyd lifters dosn't apply here.
But shall consider them a good set of lock-nuts if adjusment held for 2,000mi.UK Paul thx for input and 3 yrs is a good point for CC. I will look elsewhere now and leave my lifter adjustment alone. Now my list (suspicions) of questions is qrowing. Interested now in type of lifter you have. What ratio CC rocker are u using? 1.6? 1.5?
Totals time: So lets say 'bout 5 good sets to only 2 bad sets of CC Mag lock-nuts.I really can't include the Poly type locks as i'm not running those (yet).
Miss match with type of threads on studs a possible cause.
Good night.
cardo0
ltlevil
ltlevil
Its just that i'm low on cash right now and can't afford the longdistance air time for that 3-way call - need to buy some good new lock nuts instead. But maybe you could get CC and WP engineering on the phone to ask for me. With ur mental powers of investigation i'm sure u'll get those big guys straightned out.
Sorry starters where on another post. Hey try your own post on starters and then i'll get to study that.
But for now i'll continue with this poll/post.Have a nice day.
cardo0
" If this person is you
Now you can say what you want or tap your toe or any of those other comments you made before, but I truly was trying to help you, sorry I didn't realize you didn't want help fixing the problem
just wanted to have something/somebody other than yourself to blame it on.ltlevil
Best method is just to put'm on ur ignore list.
I still would enjoy to hear from anyone with CC Mag rockers having vlv train noise or not.
I'm greatly interested in this due to all the recent posting of wiped cams from CC and having 2 nuts loosen up my rockers right at break-in.
I appreciate all your tolerance here with some real nonsense.
cardo0
I don't see a great use for the personal engagements on this thread (or on a couple of others.) If any respondee is bored or annoyed by the starter of a thread - make that clear once, then move on. What possible purpose does it serve to engage someone over and over you just don't like or regard as foolish?
On the other side, if you do have the huevos to post something you are having a problem with that might cause ridicule, it doesn't seem a posted conversation is enough to expect reps of manufacturers or other overly interested parties to jump in and attempt to sabotage this complaint - it's probably a legitimate disgreement, even if personally based. It doesn't follow that such a disagreeing party is necessarily wrong either.
(I really don't accept to many excuses or disparaging remarks from manufacturers' sales staffs either. The bubba car parts industry is not really known for customer support.)
These CC ProMags are now the staple of best valvetrain equipment, like the original Harland Sharp's used to be. There may, nonetheless, be something going on that didn't used to with aluminum bodied rockers. Having put them on in place of cheapy ProForm $100 Sharp knock-offs, I doubt there really is much impact under 8K.
I know I learned something here may involve different thread types, which I had never considered - so something concrete came out of this dialog. Think I was going to learn that from a factory rep right out in the open?
I know a similar "current best" product - the MSD ProBillet distributor -has a bad tendency to leak - and leak badly - at the slip collar until you RTV it in place, which is hardly emphasized in their literature. Few mechanics were familiar with it. (Personally, I think they should redesign that slip collar to be a continous piece - spiral, tongued-in, whatever.)
What a shame it would be if such dialogs became repressed from either excess personal criticism or dismissal out of hand of those who don't agree as being trolls.
So i reviewed this poll/post again for another look and found my acounting off by 1 bad set of Poly-locs that finaly worked out. So the revised results are: 2 bad sets - myself (cardo0), Redbad79 (curious not at idle for Redbad)
5 good sets - Page 62, Stingr69, Ragg (but using solids), Yellow73 and PaulUK
From this short list the bad sets are over 25%
Not good!But the Polyloc users are 100% good sets and only 1 set with inital problems that recovered
GoFast deserves an honnorable mention here with some great insight on threads.
I need more data. And would like to run this poll to 100 responses looking at CC May self-locking nuts. But i'll feel lucky if we hear from 50 in a reasonal time.
Well anyways i need time to shop for taller vlv covers and new gaskets (can't recall brand, using the 1/4" or 5/16" thick cork set now and they really work great) and of course a set of Perma-locks.
Your responses will only help other vette owners in the future avoid this problem. I have to say this is really one of the great benifits of this forum. And i'll verify we have brainstormed other problems here before with good results.
cardo0Please forgive my previous math errors (spelling too). :o cardo0
Last edited by cardo0; Jul 17, 2005 at 01:44 AM. Reason: revise info, recalculate and typo
Now i just have to put them on and adjust the vlvs for the 4th time.
cardo0
cardo0
It's definitely worth investigating
