Polylock Torque Spec.
Old Jun 27, 2005 | 12:38 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Polylock Torque Spec.
Does anyone know the torque spec for the locking Allen screw on the polylocks for Comp Cams roller rockers?
Hand tight with a 3 inch Allen key? Breaker bar with moderate force? Impact wrench set on kill?
Presumably closer to the first guess?
Old Jun 27, 2005 | 02:37 PM
Matt Gruber's Avatar
Matt Gruber
i use 20#
Old Jun 27, 2005 | 08:15 PM
C3 Stroker's Avatar
C3 Stroker
I go by "feel", but my instructions stated 15-20 ft.-lbs.
Old Jun 29, 2005 | 12:12 AM
Solid LT1's Avatar
Solid LT1
This was taught to me buy a NHRA national record holding machine shop owner: Set the allen lock set-screw, and turn the poly lock hex into the stud about 1/8-1/3 of a turn to "lock" the poly locks into place. Be careful with this method, you can overdo it and the next time you try to back them off, you'll pull the studs out of the cylinder head. I used to have trouble with my valve lash holding but, I never have after adopting this system.
To Polylock Torque Spec.
