Spals installed - Finally TEST DRIVEN!
Well now it has two Spal fans and let me tell ya - it runs COOL!
Odd behavour though - in traffic they run 90% ON time, but my engine temp is 185* or so. Seems like they could relax a bit, and let it get up to 195* or so, just before the halfway point on the gauge.
I drove it to the radiator shop that custom-built the radiator and they verified the temps with a radar gun. Radiator (after a half hour drive) was 185* and the water neck was 165* so I think it's
and also
for now.I think this chapter is licked.
The spal fans came with wiring that was fitted with crimp connectors. I cut them off where possible and soldered, but there are still a couple of crimp connections in the system. Any thoughts on that? Also, was SPAL the manufacturer that had problems a couple months back, with the inline fuses catching fire? Or was that Flexalite or another mfgr?
I had flexilites before the spals and the fuse is melted into the holder, but have had no such problem with the SPals.
BTW, I wired one of the spals to a manual switch and the toher to the temp sensor. Often just the one fan does the trick, and I can switch on the other as necessary.
I never paid attention to how much mine run...can't hear them over the sidepipes....
Regardless,
and happy driving!
Where did you get your kit from and what switch did they sell you? I got mine from BeCool.
Sounds like the switch I need. Mine is a 185/165 ...
Vendor is an official Spal dealer (purch from Ebay) and all the packages say SPAL right on them.
and also
I love the desert but with this BB, DeWitt's aluminum radiator, and dual Spals, and 105 degree temps, the motor runs about 210 degrees...
The entire car then suffers from heat soak from stopping and going, so the fuel is boiling in the fuel bowls...... The real test would be out on the open road with no traffic to deal with.
Any way you look at it, the Spals work very well!!!!
Bob
Bob
