Holly 4150 Idle Adjustment?
Old Jun 28, 2005 | 05:32 PM
72-LT1's Avatar
72-LT1
Default Holly 4150 Idle Adjustment?
Hello all,
I bypassed my TCS valve and went strait to the vacume advance on the distributor with my vacume line, set the timing to 34deg, all in at 2700RPM. After the adjustments my idle jumped up to about 1000RPM with the vacume connected.
My question is, is the idle agj on the dirvers side of the carb, inside of the throtle assembly? I will eventually get a Holley book but I need to get the idle back to about 700 for now.
Thanks in advance
Old Jun 28, 2005 | 07:35 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
There will be a screw on the driver side of the base plate that you will see touching the throttle arm. Just back it off.
Old Jun 28, 2005 | 09:26 PM
72-LT1's Avatar
72-LT1
Thanks, that the one I thought it was. Got er done.
To Holly 4150 Idle Adjustment?
