Clock work??
Old Jun 29, 2005 | 03:52 PM
1974 C3's Avatar
1974 C3
Cruising
Default Clock work??
..Just a note in general to say thanks for all the help you guys give out , .i dont post much,can find almost everything i need just by listening in and printing off the good stuff. my mechanic loves my hand full of printed postings when i bring the car to the garage .BUT i am i need of a clock repair on my 74...any help with that, .....were to send it, buy new , ..etc.etc.. .....Thanks for the help and have a good 4th ......p.s.(while im asking for help) does anyone have a 74 with a alarm that works???, and the push button starter under the hood??.....thanks again!!
Old Jun 29, 2005 | 04:21 PM
rihwoods's Avatar
rihwoods
This thread in general had good tips:
Clock works !!!
http://forums.corvetteforum.com/show...3&forum_id=119
Vette Gator's Avatar
Vette Gator
I went with the quartz conversion kit for my '76 clock. Very easy installation and it works great!
Old Jun 29, 2005 | 04:39 PM
OldSchool's Avatar
OldSchool
This guy is supposed to be very good..
http://corvetteclocks.com/index.html
Corvette Clocks by Roger
Old Jun 29, 2005 | 08:16 PM
C3 Stroker's Avatar
C3 Stroker
I bought a replacement clock (quartz type) for my '69 at Corvette Carlisle a few years ago from Roger......still working excellently.
Old Jun 30, 2005 | 08:20 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The Clock Works
http://www.clockwks.com/CLOCKWORKS/The_Clock_Worx.html
Old Jun 30, 2005 | 11:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The original clock in my '68 would alternately choose to run and not run as it saw fit. I ran a separate ground wire from the clock and it has run like a champ ever since.
Old Jun 30, 2005 | 02:24 PM
zymurgist's Avatar
zymurgist
I did the quartz conversion when I had the center console out for stereo installation. Now the clock always works.
Old Jun 30, 2005 | 02:39 PM
fast idle's Avatar
fast idle
my 75 had good ground but the power wire was loose,i tightened it up and it worked, so i oiled it up and now it works fine.
Old Jun 30, 2005 | 08:28 PM
68350hp's Avatar
68350hp
The alarm on my '74 works. Use it all the time. It died for about 20 years for my aunt then one day I opened the door and it went off. Has worked ever since. Sometimes I have to turn the key on and off a couple of time to get the alarm to arm. The clock in my car works every time I drive it but dies about an hour after I shut off the car.
Old Jun 30, 2005 | 09:42 PM
Kdarrin's Avatar
Kdarrin
I hate to give secrets away, but To date, I got 3 GM type clocks working for about $2.95.....providing the points and electrics are good in it, Try a shot of WD-40, it has worked and the clocks are still running
Old Jul 1, 2005 | 05:42 AM
Razorhorn's Avatar
Razorhorn
I put a quartz conversion clock from Roger six months ago. No problems - recommended.
Old Jul 1, 2005 | 06:16 AM
theandies's Avatar
theandies
So my Hurst Competition plus thread was moved but this one stays in tech/performance
I DON"T LIKE THE SPLIT
BTW - My clock works because I installed the quartz kit
To Clock work??
