5 Spd/6 Spd Question
Old Jun 29, 2005 | 03:59 PM
82Powerhouse's Avatar
82Powerhouse
Default 5 Spd/6 Spd Question
1982 Corvette
350 CID
700 R4 Transmission
Has anyone ever used one of these transmissions? I would really like to put the 6 Spd in, but I was told that a 6 Spd would not fit in an 82 vette. I don’t know if they were talking about all 6spds, or if it was the current one for this year. I would also like to know the quality of the tranny if anyone has used them. If these are not good, any suggestions would be appreciated.
TIA,
CDM
http://store.summitracing.com/defaul...rsview=sku&Ns=
Old Jun 29, 2005 | 04:14 PM
BerniesVette's Avatar
BerniesVette
I'm sure you will get more posts on this but will start. From what I have heard the Richmond transmission, it is one of the best. It will fit your car but you will probably have to rework the tunnel a little. Be sure to pick the correct tranny. Some of them have one-to-one final ratios and others have .76 to 1 ratios. If you are wanting it for overdrive use the .76 to 1 is the one you want. Hope this gets you started There are other trannys out there that will do the same thing. Keisler 5 and 6 speed trannys bolt in without modification and are overdrive units.
Bernie
Old Jun 29, 2005 | 05:22 PM
Brown78's Avatar
Brown78
I have a Keisler 5 speed with .68 over drive. I love it. 93 mph @ 2500 rpm's
Old Jun 29, 2005 | 05:30 PM
ram82fire's Avatar
ram82fire
I run a tko in an 82 ,,,, the 700 and tko are the same length installed . The modification to the crossmember is very simple and involves lengthening the mount perch . Of course you must do the pedals etc but all in all no biggie .
Geo
Old Jun 29, 2005 | 05:59 PM
jpatrick636's Avatar
jpatrick636
Who told you they would not fit? I would talk to a tech at Richmond or Kiesler. I have a Richmond 5-speed. It's tight but it's in.
Old Jun 29, 2005 | 09:33 PM
69vettester's Avatar
69vettester
I installed the Rich. 6sp(ROD) trans 2 years ago and documented all the details as it went along. The Fit is GREAT, The crossmember must be made removable thats all, well worth it to get an Overdrive gear.
Here is the url if youd like to see how The ROD installs in a C3. www.weavermill.com/trans/richmond.htm
Tom
Old Jun 29, 2005 | 09:55 PM
Robert Hall's Avatar
0Robert Hall
Former Vendor
I believe he was saying the ROD 6 speed wouldn't fit
Old Jun 29, 2005 | 10:05 PM
0Robert Hall
Former Vendor
Hello 82 Powerhouse -
The Keisler 5 Speed would be your best bet because:
1. It bolts right in with NO modifications or fabrication
2. It really is a complete kit, so you don't have to waste your time chasing down parts, waiting for stuff to be delivered, finding out you have the wrong part, putting your project on hold while trying to the right part ...etc
It comes with a brand new customized TKO, new driveshaft, speedo cable and gear, reverse light wiring, X member bracket, mount, pilot bearing and all the nuts and bolts to install it! Keisler also has everything to convert from an auto to a manual including BRAND SPANK'N NEW ALLOY 621 STYLE BELLHOUSINGS and an optional hydraulic clutch setup so you don't have to fool with linkage.
3. You know it will all fit, and it comes with a warranty
4. The tranny is very strong and has a real overdrive.
5. You'd be hard pressed to buy a ROD and then buy or build all of the other parts needed to install it for less $, and even then you still wouldn't have as nice a tranny, the overdrive would not be as good and you'd have spent alot of your own time.
Robert Hall - Keisler Engineering sales
Direct Line 423-773-9789
Main number 865-609-8187 ext 280
1966 327/300 Factory A/C
Keisler 5 Speed Vette #001 !
Old Jun 29, 2005 | 10:30 PM
70 LS1's Avatar
70 LS1
I would go with either the Keisler 5 or 6 speed. They are both Tremecs and are top quality. I have a Tremec T56 in my 1970 and absolutely love it. .5 to 1 second overdrive turning 1500 RPM at 70MPH. And when I swap in the 4.33's it will be 75 at 2000RPM.
Old Jun 29, 2005 | 10:45 PM
Chuck Harmon's Avatar
Chuck Harmon
I installed the ROD 6 speed in my 69. Without question the best mod I ever made! As was said earlier, make crossmember removable. I strongly argued against this in the beginning; but, life was much easier after making center section of the crossmember a bolt in. Drive shaft needed to be shortened too.
The Longs shifter that comes with the tranny is first rate. I went with the .80 or .82 at the suggestion of Richmond because it was stronger when used behind my L88 big block.
Chuck
Old Jun 29, 2005 | 10:46 PM
Chuck Harmon
The Longs shifter that comes with the tranny is first rate. I went with the .80 or .82 overdrive gearing at the suggestion of Richmond because it was stronger when used behind my L88 big block.
Chuck
Old Jun 29, 2005 | 10:51 PM
69vettester
82 powerhouse...The ROD 6sp does fit GREAT in a C3 corvette! Ive been down this road already. My 2cents worth is dont compromise till your sure you cant make a trans with an Overdrive gear fit. Look for documentation with pictures before commiting to any aftermarket trans.
I couldnt find one vendor for any of the possible 6sp transmission upgrades that would bonify the install in a C3 Vette. I did find a bunch of guys on the forums that were installing either ROD's or T-56's, Both had their own difficulties. In fact chuck Harmon was one the guys posting results That I checked out a few years ago before I committedto the ROD.(Hope you dont mind me dropping your name in my post Chuck).
I Dont know anyone who wasnt extremely happy with the results regardless of the problems encountered, Me most of all...
Again this is merely my 2 centavos worth with pics included.
Tom
Old Jun 29, 2005 | 11:17 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Not to mention that Robert and everyone at Keisler are great to work with! I just installed the 5 speed .68 in my 80! Great service and the man that shares the Keisler name is just as great! Thanks!
Ed Dolanski (Dallas)
Old Jun 30, 2005 | 02:15 AM
Graemeinvette's Avatar
Graemeinvette
We have just finished installing a T56 6 speed during the general rebuild of my 70, have a look here at the photo's:
www.graemeinglis.com
Old Jun 30, 2005 | 02:19 AM
Kalway's Avatar
Kalway
Personally, I'd go with the keisler 5 speed. I've heard nothing but great things about it and they even have representation on these very boards.
Old Jun 30, 2005 | 09:51 AM
80TexasC3's Avatar
80TexasC3
Great Way to document the restoration! Looking GREAT!
Old Jun 30, 2005 | 03:18 PM
Older Than Dirt's Avatar
Older Than Dirt
Tom
If you're going to make the change.........go with ROD.
To 5 Spd/6 Spd Question
Old Jun 30, 2005 | 04:20 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Chris (69myway) used the ROD-6, He sez he loves it
Old Jul 1, 2005 | 09:35 PM
1atti2d's Avatar
1atti2d
My 5-speed from Keisler is supposed to be shipped out next week.
Been waiting for a long six weeks. It will be worth it, I'm sure!http://forums.corvetteforum.com/newr...&p=1551236550#
Old Jul 1, 2005 | 10:46 PM
lowbuck72's Avatar
lowbuck72
If you're on a budget and not making too much horsepower, a WC T5 is a good way to go. Almost a bolt in, just had to make a dogleg on the shifter so it comes out in the stock position. .68 OD is nice. Usually less than $400 for the whole conversion.
