Power Steering Control Valve
Old Jun 30, 2005 | 11:02 PM
fcoppola's Avatar
fcoppola
Default Power Steering Control Valve
What is recemmonded .. new / rebuilt?
Is it a simple bolt on replacement? From what I can tell a cotter pin and a few bolts are all it takes.
Any special tools or gotchas?
I have the haynes and an AIM and it looks very straight forward?
Any recommended replacements other than new hoses? I'd like to get all the parts rather than start and realize I should replace something else while its out.
Old Jun 30, 2005 | 11:19 PM
ManFromEagle's Avatar
ManFromEagle
Everyone has a differant opinion on this topic. The one thing most agree on is you might as well rebuild your own vs buying a rebuilt.
It's not hard to rebuild and you can buy rebuild kits from most parts places.
Check out www.corvette.faq for some papers on doing it yourself by Jim Shea.
Old Jun 30, 2005 | 11:51 PM
71SoCal's Avatar
71SoCal
I bought a rebuilt one last year from Corvette Central. It took an afternoon to install it, but it wasn't too difficult...except that I didn't have a pickle fork and had to rent one.
When I did mine, I replaced all four hoses too. It's been working great so far...
Old Jul 1, 2005 | 01:43 AM
stickboy's Avatar
stickboy
You can get a rebuilt control valve from autozone. It comes with there limited lifetime warranty so if it ever leaks, just take it back for a new one. When I got mine they had one in stock, has been dry for over a year now. I tried rebuilding mine and it started leaking a month later. They also have the same deal on rebuilt brake calipers as well.
Old Jul 1, 2005 | 03:19 AM
Richard Cooper's Avatar
Richard Cooper
I agree with stickboy. I got mine from AutoZone 3 years ago and its been fine. Cheap too. I rebuilt mine and it only lasted about 2 months. If the one from AutoZone ever fails they will replace it for free.
I also bought a pitman arm puller from them to get the pitman arm off the old valve. It cost me $15.00 and was well worth it. Just be careful when you start the car, DON'T put your arm through the steering wheel while turning the key. If the valve is not adjusted the wheel may turn hard to one side or the other. Its not a big deal you just remove the end cap and adjust the nut to center the wheel. The directions come with the valve. Easy job.
Old Jul 1, 2005 | 08:25 AM
ManFromEagle
There are a lot of threads on this topic on the site. Do a search and browse and see what others have had to say. It will throw some light on a few topics you are not getting in this thread.
Old Jul 1, 2005 | 01:38 PM
Chopper Larry's Avatar
Chopper Larry
Just yet another opinion....I redid the entire front suspension AND the entire steering package at the same time; that way everything is tight and one new component does not cause more wear on the older stuff.
Like Alan Jackson's new song "It don't take long, it just takes money".
Old Jul 1, 2005 | 02:04 PM
Jlreyna's Avatar
Jlreyna
You can get them from Autozone?
Old Jul 1, 2005 | 02:12 PM
Scudd's Avatar
Scudd
Had a rebuilt one put on last year. It's now leaking. I'm thinking I might go with a new one when I replace it.
Old Jul 1, 2005 | 03:39 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Rebuilt ones have a longer warranty than new ones do. 5 yr on the rebuilds 1 yr on the new ones.
Old Jul 1, 2005 | 03:45 PM
mvftw's Avatar
mvftw
I got mine through ZIP, no problems so far...
http://www.zip-products.com/Zip/prod...7D54B2E27F594D
Old Jul 1, 2005 | 09:07 PM
fcoppola's Avatar
fcoppola
Some great advice here .. I have an autozone nearby, and if it has a lifetime warranty, I just assume do that.
What special tools do I need to get? Whats a pickle arm?
From what I can tell its a cotter pin and a bunch of bolts. I'll pull out my AIM tonight and start getting detailed. I'll also do a search on here. I got lazy last night when I posted.
To Power Steering Control Valve
