Head light switch removal
Old Jul 2, 2005 | 12:13 PM
vettenut2's Avatar
vettenut2
Default Head light switch removal
I have a 1980 that I'am trying to remove the dash pad in. I don't see how to release the shaft from the switch, or how to remove the wiper switch. Any help would be appreciated.
Old Jul 2, 2005 | 01:37 PM
Vette Gator's Avatar
Vette Gator
There is a small button on the side of the switch. Push in and hold this in while pulling on the **** and the shaft will come out.
Old Jul 2, 2005 | 04:37 PM
bams12's Avatar
bams12
I found the best way to get at the headlight switch was to remove the instrument cluster first. Especially if you are going to want to remove your wiper switch as well. Take off the little panel below your steering column and loosen the 2 bolts holding up your steering column. Take all the screws out of your cluster lens and your cluster and remove. Then you will have access to your switches. There is a little release button on the right side of your headlight switch that needs to be pressed to release your switch ****.Next is a nut on the front side of your dash that you must thread off. Then you will have to release the electical connectors and the 2 vacuum hoses. The wiper switch has 1 small screw with a nut style head that must be removed along with a couple electical connectors. Hope this helps. Brent
Old Jul 3, 2005 | 01:31 PM
vettenut2's Avatar
vettenut2
Default Thanks
Thanks for the info guys. I now have the dash on the floor of my garage.
To Head light switch removal
