G Timer , anyone using one?
Old Jul 3, 2005 | 05:49 PM
73jst4fun's Avatar
73jst4fun
Default G Timer , anyone using one?
Is anyone using the G Timer by Cinn. Microwave? I'm going to try The G Tech Pro this week and wanted some kind of comparison on the two units. I know the Pro has more options, just wondering about the accuracy of the units....Thanks
Old Jul 4, 2005 | 10:23 AM
73jst4fun's Avatar
73jst4fun
No one????
Old Jul 4, 2005 | 12:05 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I have HP tested about 20 cars with a G-Tech performance meter. It repeats well, however, it gives lower readings than a chassis dyno, mostly due to the fact that you are spinning up your front wheels during the run AND there is no incentive for the meter to show big numbers. I work with test machines and faulty calibration can give any result one wants - most people want big numbers so the shops provide them.
Some results:
'63 327/300 170 RWHP
'69 350/300 165 RWHP
'69 L-88 Spec 427 345 RWHP
'69 355 Highly Modded 320 RWHP
'01 Yamaha R6 96 RWHP
'93 Kawasaki ZX6 69 RWHP
'93 350/375 ZR1 Modded 313 RWHP
'93 350/300 Net Corvette Auto 193 RWHP
'03 Trailblazer rated 270 198 RWHP
'68 327/275 9.5 CR 145 RWHP (Impala)
'02 350/350 Modded 274 RWHP
Unless specified these are all Corvette Engines in Corvettes.
The numbers are good for comparison purposes and are repeatable. You cannot hit the shifts hard or allow automatics to shift as that gives inflated false readings. (picture a 3 hp Briggs and Stratton spinning up a 1000 lb flywheel and then engaging that spinning flywheel to the ground......)
Old Jul 4, 2005 | 03:44 PM
73jst4fun's Avatar
73jst4fun
Thanks for your good information......I can use the numbers for a good baseline and any future modifications and performance improvements should show up on the graphs........
To G Timer , anyone using one?
