Steeroids user-what size nuts..
Old Jul 4, 2005 | 02:54 PM
Fevre's Avatar
Fevre
Default Steeroids user-what size nuts..
for the steering shaft support bearing (heim joint)?
Old Jul 4, 2005 | 03:25 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
in between 1 1/16 and 1 1/8 and in between 27mm - 30mm
hows that for an answer
Old Jul 5, 2005 | 05:51 AM
Fevre's Avatar
Fevre
I'll shoot Speed Direct an e-mail.
Old Jul 5, 2005 | 08:25 AM
bobs77vet's Avatar
bobs77vet
let me know and i will buy a 1/2 socket to match i suspect its either a 28 or 29 mm, funny how they pick sizes nobody has the tools for...can you imagine trying to find a 1-3/32 size...it would probalby cost a zillion dollars
Old Jul 5, 2005 | 08:51 AM
Fevre's Avatar
Fevre
And they are not listed in on the instructions, guess I might be able to get the end nut off and take it to the store to size up but am scared I won't be able to get it back on, not much run in there, can't even get my large box end wrenchs in there to check if any I have will work.
Old Jul 5, 2005 | 10:02 AM
bobs77vet's Avatar
bobs77vet
can't remember how i tightened mine up...i guess i used an adjustable wrench. i did put mine in when the engine was out, though. to check for you yesterday i just slipped sockets over the end nut.
Old Jul 5, 2005 | 01:25 PM
Fevre's Avatar
Fevre
Got an e-mail back saying 3/4" , can't even get a 7/8" wrench close to going on em.
Old Jul 5, 2005 | 01:33 PM
bobs77vet's Avatar
bobs77vet
i bet the bolt diameter is 3/4"....maybe its a Whitworth nut....they measure those nuts and bolts by the diameter of the shaft, just kidding....
Old Jul 5, 2005 | 01:42 PM
Fevre's Avatar
Fevre
Didn't even think about that, he did give me the thread count too, see what he replies
Old Jul 5, 2005 | 03:03 PM
rcread's Avatar
rcread
I've never taken steeroids, but in regards to nuts, I heard they get smaller.
Old Jul 5, 2005 | 03:21 PM
Carl Johansson's Avatar
Carl Johansson
These guys must have to much time on their hands - trying to put undersized wrenches on their nuts! Sheesh - kids today!
Old Jul 5, 2005 | 10:12 PM
Fevre's Avatar
Fevre
And the answer is:
You need a 1 1/8” wrench (1.125”) or roughly a 29mm Metric... Honestly, we usually use crescent wrenches, but if tightness is the issue, you may need a standard open end wrench…
Best I can do so far is channel locks, just not enough room for a crescent wrench to get them tight, guess I might be looking for a 1 1/8" or 29mm open end wrench, might have the raid the old man's tool stash and see what he's got.
Old Jul 5, 2005 | 10:16 PM
bobs77vet's Avatar
bobs77vet
And the answer is:
[qoute]You need a 1 1/8” wrench (1.125”) or roughly a 29mm Metric... Honestly, we usually use crescent wrenches, but if tightness is the issue, you may need a standard open end wrench… [/qoute]
not sure the open end or box end will work.....can you use a socket? in any event i bought a 1 1/4" wrench the other day at Pep boys for $18...
Old Jul 6, 2005 | 05:13 AM
mrvette's Avatar
mrvette
All my wenches above 7/8 are some older Taiwan set I got years ago...not used enough to bother getting American tooling, they even are accurate as to size, beleive it or not..
GENE
Old Jul 6, 2005 | 09:00 AM
Tomi72's Avatar
Tomi72
I think the nut is 28mm, atleast that is what I used on it...
To Steeroids user-what size nuts..
