pull when braking
Jul 5, 2005 | 01:28 PM
pull when braking
When I brake it pulls hard to the left. Does that mean the right front calipher is the culprit?
Jul 5, 2005 | 01:44 PM
Cruise-In II Veteran
Could be left front; could be alignment; could even be air pressure.
Jul 5, 2005 | 01:46 PM
If nothing's obviously leaking & your pads are all good, bleed everything & see what happens.
Jul 5, 2005 | 02:07 PM
Quote:
I agree the problem stems from the right. That caliper for some reason is not doing it's share of braking. I would look to that side first.
Jul 5, 2005 | 02:19 PM
Quote:
Jul 5, 2005 | 02:28 PM
How about when there is Brake Fluid all over one of the LEFT pads....
Jul 5, 2005 | 02:50 PM
First,check for leaks..if no leaks... you can try this: Switch pads from left to right on front (wheel to wheel)...it worked for me once....
Rich
Jul 5, 2005 | 02:54 PM
Caliper could be sticking but do not overlook bleeding the brakes or it could be the lines are collapsing. My $0.02
Jul 6, 2005 | 11:05 AM
Thanks for your input. FYI, new brake lines and bled, no leaks, and tire pressure checked. Caliphers are old, but are ss with dot 5 brake fluid. Think I'll change pads and rebuild right side to see if that solves the problem.
Jul 6, 2005 | 07:17 PM
better check your controll arm bushings, ball joints, tie rod ends & other related front end parts...... sounds like something is worn-out!!!
Jul 7, 2005 | 05:00 PM
I had the exact same problem...turned out to be a bad brake line. I replaced with braided steel and all was good.
Jul 8, 2005 | 06:03 AM
Quote:
Same here. And another time it was the lower control arm attaching point on the frame that had a crack.
Stephan
