Custom gauge setups
Old Jul 7, 2005 | 06:45 PM
  #41
PolishMike's Avatar
PolishMike
Originally Posted by corvetteatv7
I have an aluminum plate for a '79 for the tach speedo, that i had professionally cut, but they took too long, so i built my own and used it. If anyone would like to buy it, give me a shout. It does have the holes for the brights and so on in the middle too.
Is it the same as a 75? (sorry, still learning here)
Pics?
While were on the subject,
My car is going to be a mildly built 502. What Gauges would you guys recommend?
Definatly
Water,
Oil pressure
oil temp
voltage?
Probably going to have a wideband setup with EGT so i dont think i need a guage there.
Should i get a trans guage?
Old Jul 7, 2005 | 06:49 PM
  #42
Twin_Turbo's Avatar
Twin_Turbo
water temp, oil temp, oil press, fuel press and voltage are the minimum I'd want.
a wieband O2 w/ EGT? Where do you get those? The champion thermocoupler plugs would be nice but i think they're still not available on the market.
I have the following:
oil press
oil temp
water press
water temp
trans oil temp
fuel press
fuel level
voltage
EGT 2 band
Vac/Boost
thinking about adding intake temp (if there's such a gauge, maybe use a general temp gauge...will have to look through autometer catalog)
Old Jul 7, 2005 | 10:06 PM
  #43
corvettecris's Avatar
corvettecris
Here are my cobalts. Just waiting for the 5'' tach/speedo to come out.
Old Jul 7, 2005 | 10:47 PM
  #44
84rzv500r's Avatar
84rzv500r
Just posted pics under my corvette photos, should be available shortly.
I have am finishing up a custom dash kinda NASCAR style...
Main panel:
Switches for Wiper lo-off-high
fan auto-off-manual
rear hatch release
Fuel pump
Water temp
0-8000 tach
0-200 speedo (elect)
Oil Press
Oil Temp (Backordered/elect)
Fuel Press (elect)
Fuel Qty
Volts
Center panel TBD
CD/amp
Bat Disconnect,
Diff Temp
Trans temp
Clock
Vac
Aux switch pannel
also installed a ECU interrupter switch
Old Jul 8, 2005 | 12:48 AM
  #45
ltlevil's Avatar
ltlevil
Here's a pic of mine, Tach is a little canted in the pic but that's straight now. Who ever said it was easy knows more than me.
Old Jul 8, 2005 | 11:30 AM
  #46
84rzv500r's Avatar
84rzv500r
Mine's a work in progress...
http://forums.corvetteforum.com/phot...23mvc-001s.jpg
Old Jul 8, 2005 | 12:03 PM
  #47
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im leaving mine all stock and putting in a water pressure guage.
Old Jul 8, 2005 | 01:49 PM
  #48
corvettecris
Originally Posted by 84rzv500r
That's a lot of gauges!
Old Jul 8, 2005 | 01:50 PM
  #49
Charlie's81's Avatar
Charlie's81
That's going to look sharp when you get it done, I like the NASCAR style dash!
Old Jul 8, 2005 | 03:52 PM
  #50
Corey_68's Avatar
Corey_68
Any idea on the ETA?? When I called Autometer they said "It will be a while" so I went with the Ultra-lites.
Old Jul 8, 2005 | 03:56 PM
  #51
corvettecris
No idea. but they said they were coming, and my car has a ways to go yet, so I can wait them out... Hopefully. Or else there may be a set of cobalts for cheap in the FS section in a few years.
Old Jul 8, 2005 | 06:07 PM
  #52
pef427's Avatar
pef427
[QUOTE=ltlevil]Here's a pic of mine, Tach is a little canted in the pic but that's straight now. Who ever said it was easy knows more than me.
What did you use as a trim ring around the gauges since they do not fit the holes?
Old Jul 8, 2005 | 07:43 PM
  #53
corvetteatv7's Avatar
corvetteatv7
Pics?
Definatly
Water,
Oil pressure
oil temp
voltage?
Nope don't think so. Check out my corvette photos and you will see one of the gauges and what they are mounted on is the one i made. the other phone is exactly the same just neater because it was professional water cut. Just didn't have the time to wait for them to finish it.
Old Jul 9, 2005 | 08:11 AM
  #54
LiveandLetDrive's Avatar
LiveandLetDrive
Originally Posted by nvvetgirl
Is there something you can do with the heat/ac switches. I love you guages set up but want to get rid of or move the heater/ac switches.
You could use a '77 console with those controls mounted in front of the shifter. The wiper controls are in the column, I don't know where they are on earlier years.
-Chris
Old Jul 9, 2005 | 04:13 PM
  #55
WayneLBurnham's Avatar
WayneLBurnham
Default Yeah, there is - at least from Nordskog...I've got one
oil press
oil temp
water press
water temp
trans oil temp
fuel press
fuel level
voltage
EGT 2 band
Vac/Boost
I stupidly used an external air temp sensor for it and it melted. I'm going to use a reg water temp sender when I hook it back up.
I really don't see how much a wide band helps over the common narrow band a/f gauge - unless you are way out of range such as in a diagnosis of error situation. I was about to get the new nordskog digital pyro, but the engine needed the bucks more right now.
What I need is an AB switch - ideally one that automatically flips back and forth on its own at regular intervals - that will switch between right and left bank a/f, pyro and head temp. I haven't even decided whether to use the head temp gauge or not - can't see the huge difference between it and water.
Old Jul 10, 2005 | 04:01 AM
  #56
Twin_Turbo's Avatar
Twin_Turbo
You can't just hook a switch to a pyro, the sender and wire length are specific, if you alter the wiring in any way the ohmage will be off and the gauge will not read correctly
Old Jul 10, 2005 | 12:58 PM
  #57
WayneLBurnham
Default So I would need to measure the resistance and impedance
and match them on each wire then (and with the switch wired in)?
I know Summit and Jegs sell pyrometer sensors seperate from the gauges....;Nordskog sells theirs as a package.
Generally, I would think relatively thin copper wire and all solid connections would have very little resistance.
Assuming my temporary engine can be healed, and cheaply (should know by Tuesday) I'll make sure to ask Nordskog about that.
To Custom gauge setups
Old Jul 10, 2005 | 06:08 PM
  #58
Twin_Turbo's Avatar
Twin_Turbo
Yes, you would need to measure the impedance (which is resistance) and get it dead on to be correct, but you'll need to know what impedance refers to what temperature. I wasn't aware that summit and jegs sell seperate wiring kits, unless theya re for sue w/ a specific gauge or brand of gauges (or some kind of control box)
To switch between banks you're better off jsut getting the dual pyro controller from autometer or such.
Old Jul 10, 2005 | 06:58 PM
  #59
PolishMike's Avatar
PolishMike
wideband is a million times better than narrowband. All you see on narrowband are GUESSES. Have you ever seen a narrowband log? it shoots all over the place. tells you very little about how your car is running. wideband will give you an accurate ratio no matter what your throttle position is. You know that 11.7:1 is 11.7:1. With narrowband it will give you a certain voltage but there is no way to know what ratio it actually is. It is also very hard to see what is going on at anything besides WOT.
Old Jul 10, 2005 | 08:57 PM
  #60
WayneLBurnham
Default yep, I have twin a/f gauges....and, when I haven't nuked
them from getting soaked in oil or tranny leaks, they are VERY predictive and sensitive to how I have the carb set.
You could tell EXACTLY when you transitted across the steps on the fuel rods on the Edelbrock when it was on the car with the last engine. Between those and the vacuum gauge there was NO guesswork involved at all in picking jets and rods on the AFB.
The full range of those narrow bands may only have been from, say, 11.5 to 13.5:1 (I don't know) but that was where it is most useful for functioning. On a dyno where you are expecting to find problems you need to know when you have 8:1 and 16:1, but not on a running setup you expect to be near, but not perfect. Plus, when you hit over range on the narrow bands, they peg in the correct direction, lean or rich.
There's no guesswork with those sensors, even if they will not read the full range a wide band will. As far as what corresponds to what exact ratio, calibration is always an issue, but my plugs always reflected the expected neutral or lean or rich readings and the two gauges agreed with each other with the same carb settings on each side.
I don't know the center of my display with narrow band is definitely stoichiometric - but, then again, neither would I with wide band - either way I have to experimentally verify that against other indicators like plugs and running temps or just trust the electronics that are interpreting the signal.
As far as throttle position - that was where they really shine! You'd have a nice mid range slightly lean cruise A/F ratio, hit the gas, watch the vacuum drop below 8 or 10" and INSTANTLY watch the A/F lean out and you KNEW you had to change to a narrower stepped fuel rod on the skinny end. Alternately, if they went more than a little into the rich area, you knew you needed a fatter one there - and I DID have that predict an over rich on acceleration stumble once.
I really miss how nicely you could set up AFB's with these things, with their segregated bank to bank fuel, but lacking the big fuel bowls and "squirters" of a holley, they just lack the responsiveness, even if I have a harder time setting them up.
To me, more useful than wideband vs. narrow band, was how quickly they respond, whatever their range, how long they last (I seem to need several sets a "normal" year - whatever that is with this last stupid year with this albatross engine) and that I should stop being so cheap and get some self heating ones!
