Custom gauge setups
Im thinking about making a custom cluster and everything. What do you guys think?
I'm going out to drill the holes !!
I've seen posts of Cobalt Clusters but no Speedo or Tach.
as for the gauge cluster, i'd recommend you use the existing cluster and again modify it. what I did was drew up a flat face for the entire panel in autocad, and took it to a machinist to have CNC'ed. I then drilled and tapped through this front face, into the old cluster (which I had gone to work on with a grinder and removed much of the center material, leaving a bare bones outer frame with enough area for the mounting bolts).
This is a very old, rough photo, but it gives you an idea:
This is a later shot, showing some updates:
underneath that carbon fiber is 3/16" aluminum plate. Easy to work with.
Good luck... oh and don't let some NCRS guy talk you out of it. have fun.
the blone weasel
the blone weasel
Thats exactly what i had in mind. Thank you very much. I own a metal shop so im going to make a gauge cluster like yours. Im going all out on this vette so might as well have some nice gauges.
I may have to put a couple more gauges then you though
The stupid thing may be broken down 9/10's of the time, but the gauges are great!
Still have to do all the wiring, the indicator lights, the TRC-2 control and some other stuff....hopefully it will be sweet
I'm also still waiting on my autometer oil temp gauge, volt gauge and fuel level gauge.
http://www.classicinstruments.com/
